Progress anti-sway bar is it worth it??
i am thinking about purchasing this item and was wanting some comments on your alls thoughts on this product
click here
I can get it for 139 shipped
Thanks guys
Injen
click here
Thanks guys
Injen
Search and Learn
The best bang for buck for rear sway bar setup.
I dont have it but ive read many reviews on clubrsx,ephatch. Sway bar might hit your exhaust piping though. Better endlinks are not required but i am planning to upgrade it when i get progress setup.
Search and Learn
Originally posted by mndthegap1
prob. should have searched... BUT
since you mentioned it civicvtec1ps what endlinks are you gonna get ?
i just want to know cause i am interested in the sway bar too.
This has been posted many times before but I'll give you my $0.02.
I have the complete Progress kit and I think it's the best money I ever spent. They had a package deal with the front and rear bars w/ tie bar. It's a little pricey but you get what you pay for. Combine that with a Neuspeed upper tower brace and you get immediate results.
Forgive how dirty the underside of the car is in this pic but it was the end of winter and the roads were filthy.
Injen
Autocross Junky
You may not need it, the 22mm bar may be more then enough for your needs.......
Setting up your suspension is a tricky thing, Bigger is not allways better, and stiffer springs may actually hinder cornering.... its all about tuning to your needs...
Its a celebration bitches!
i love my progresss front and rear sway bars, i think it is the best investment i have done to it, and on top of it i have greys endlinks which are about 20 times beefer and stronger than stock. with these sway bars on a other wise stock car makes the driving expierence soooo much better and if you couple it with strut bars and a x brace and good dampers you will have a car that could(if it was fast enough) run around a porshe
why does it say that the front will fit civic 01-03 except si i mean shouldnt they know it wont fit the ex cause of that cat cause that is what people have been saying?
because the civic has the cat located under the bar. the reason the si and rsx bars are diffrent are because the cat is farther down because of how the header is in the back of the enging instead of infront like ours... well pretty much only the ex's the lx,hx, and dx have their cat on the header...
blah
ex's rule....
blah
ex's rule....
Raiool
Oct 1, 2015 10:42 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
Click on the link in my sig for more info.
