taking off oem spoiler...diy:filling the holes?
Old Dec 27, 2003
vino's Avatar
vino is an unknown quantity at this point
is there a diy on filling the holes?...i wanna see if i can do it myself
Old Dec 27, 2003
Dr5D's Avatar
I would assume its done the same as if you take off your "H"....
Old Dec 27, 2003
vino's Avatar
and how would i do that?
Old Dec 27, 2003
CPEasy02's Avatar
CPEasy02 is an unknown quantity at this point
you can get someone to weld it or the good old bondo routine
Old Dec 27, 2003
Philip's Avatar
Philip is an unknown quantity at this point
okay Vino, I suggest you leave this to a body person if you want it to look decent. you gotta use the Body Filler tape and body filler and alot of sanding than prime it and than sand it again and again......+ you might want to have a dust free spray booth if you wanta decent looking job. anyways here is a list of items you would need if you wanna do it ur self: Body Filler Tape ( the type that looks like fisht net), 80, 120, 240 3M yellow abrasive sand paper, 360, 400, 1000 wet/dry 3m black sand paper, a wooden bloack or a surface sander. fine body filler/putty, body/putty filler Hardener, a filler and hardner mixing board. P.S. : remember to use moderate hardener other wise you would waste the filler, cause it may dry too fast!!
Old Dec 27, 2003
Philip's Avatar
oh i also forgot, you will need Primer + Primer Hardner. than bring your car to a local spray paint booth to paint it
Old Dec 28, 2003
7thGenerasianCivic's Avatar
Search!!!
Old Dec 28, 2003
skipbarber's Avatar
good old duct tape works. no one will know.
Erndog81
Oct 31, 2015 03:01 PM
stryder12
Jun 30, 2015 08:33 PM
vtecbrah
19
Jun 5, 2015 09:38 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
