Stereo off, after door opened
Old Dec 22, 2003
loquio2's Avatar
loquio2 is an unknown quantity at this point
Question Stereo off, after door opened
The stereo goes off after you pull out the key, what I want to know is that anyone know how to wire it, so it goes off until you open a door, or after a few seconds after door is opened , I saw an article once, but I don't remember where . I think it involved using relays, and stuff
Old Dec 22, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
I dunno how to do it but i would love to have it on my civic. My moms 02 trans am ws6 has it and its cool
Old Dec 23, 2003
LiceLocket's Avatar
LiceLocket is an unknown quantity at this point
what do u mean goes off until door is opened? u mean, it turns back on when the door is opened?
Old Dec 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
Re: Stereo off, after door opened
gm has that feature on a lot of cars. you turn the car off and stay inside with the doors closed and the radio stays on. it stays on until the doors are opened.
let me think...
ok this would require 3 relays and 2 diodes (diodes because then if not power would feed back through the accessory circuit and turn other things on)
hows that?
basically, you take the red wire coming off your wire harness, put the side going to the car where it says accessory, and put the side going to the radio where it says radio accessory. the door wire you can get from a few places, one being from teh button looking thingie on the inside of the door sill that tells the car if the door is open or not. the fused 12v+ wire is obviously a fused 12v wire which you could even steal from teh yellow wire coming off the wire harness.
Name:	open door latch.jpg
Old Dec 23, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
are you that lazy you cant keep the key in the ignition until you are ready to get out?
Old Dec 23, 2003
loquio2's Avatar
Hey thanks, I'll try to do it, It's pretty clear, I just need to buy the relays and diodes.
Is not that I'm lazy (well I am) but it is usefull, when you are in the car and someone uses the keys for something else, etc..
ballmich
Jul 9, 2015 11:59 AM
robbie374
Jul 7, 2015 02:56 AM
Spanky4269
Jul 5, 2015 09:40 PM
