How do u make the clutch softer?
Old Dec 11, 2003
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Question How do u make the clutch softer?
i drove mah friedns 7th gen and his civics clutch was WAYYYY softer then mine.. then i drive sumone elses 7th gen and his was also WAYYY softer then mine.. so how do i make mine softer??????
Old Dec 11, 2003
blouisgod's Avatar
Life Begins > 6800rpms
ride it
drop clutch starts
beat the **** out of it
"granny shift" LOL
Old Dec 11, 2003
INCivic's Avatar
INCivic is an unknown quantity at this point
Originally posted by blouisgod
ride it
drop clutch starts
"granny shift" LOL
Old Dec 11, 2003
Decamo's Avatar
Decamo has a little shameless behaviour in the past
It could be that the seat was closer to the pedals or in a higher position than your used to that made the clutch easier to press.
Our hydraulic clutch's are so smooth and soft. In fact I think they might be too soft with not enough feel in engagement.
Old Dec 11, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
You cannot make your clutch softer to depress. If you bought a weaker pressure plate it would make the clutch softer, but they don't make weaker pressure plates. Take it to the honda dealer, something may be binding (specifically the slave cylinder hydraulic line).
Old Dec 12, 2003
AR's Avatar
AR
e-married to daydreamer
^^^ I agree with both intruder and decamo.
Old Dec 12, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Yeah. . if their clutching feels softer it's either because your's is too firm, or their clutch is weak from abuse or something. .
Also. I'm not sure if there are differences year to year. (ie. 2001, '02, and '03 models). Heck, I'm not sure there aren't differences in the trims (DX, HX, LX, EX, SI). So take what is different about the vehicles like year, and trim level.
Also take into consideration how each of you drive. If you are nice to your car, or if you beat it up. Also, the grease the dealer puts on the pedal is semi-permanent, every 5k - 10k you should regrease all the moving parts of the clutch pedal to keep it smooth and avoid grabbing and/or clicking/clunking noises.
If your pedal is retardedly more difficult to push down then I would be worried. Or if all your cars are the same, you all drive the same and your pedal has a good coating of grease on there, then I would worry about it and take it in other than that, just remember every car is different.
oh. . and lastly. The dealership can adjust it slightly to make it firmer or softer depending on how you like it. They can't change it enormously, but they can adjust it a bit. So keep that in mind too.
Old Dec 12, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
they could try bleeding the clutch fluid. i did mine after i bleed my brakes, using dot 4 ate super blue fluid. it made it ever so slightly firmer. but most of all, my clutch used to engage almost all the way out, now it's half way out. (pedal wise)
Old Dec 16, 2003
JDMsicvic's Avatar
JDMsicvic is an unknown quantity at this point
look under the steering wheel...take out the plastic..and behind the clutch assembly itself...you can adjust it slightly..i adjusted it when i got my ACT clutch installed....made a world of a difference.....
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jbander
Jun 4, 2015 05:56 PM
dinsum
May 28, 2015 09:30 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
bsmiley
Apr 27, 2015 01:27 PM
