Alpine Type-R SWR-1041D subwoofer
Used for less than 3 month. Looks and performs in perfect condition.
Price: $100 w/free shipping (this thing is HEAVY)
DETAILS:
Go ahead — crank up that volume **** because Alpine's top-of-the-line 10" subwoofer can definitely take it! The precision-crafted SWR-1041D 10" dual 4-ohm voice coil Type-R sub handles lots of bass power, and still provides the accuracy and crystal-clear sound you expect from Alpine.
The motor structure and double-stacked magnets focus magnetic energy within the vented pole piece for awesome power handling. The pulp cone has been reinforced with Kevlar® (the material used in bulletproof vests) for extra rigidity. A 1" Santoprene rubber surround aids in cone travel while guarding against decay that can mar speaker output. An extended spider landing area provides extra excursion for fuller bass.
The dual 4-ohm, 2" voice coils are big enough to handle up to 1,000 watts of peak power and provide system wiring flexibility. The tinsel leads are woven into the dual progressive Nomex spiders so you don't have to worry about them splitting apart. With this design, you'll get nearly 3" of cone excursion for maximum output. An aluminum diecast frame provides a secure, non-resonant housing.
The SWR-1041D is designed for use in sealed or ported enclosures.
Note: If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Key Features:
Kevlar®-infused pulp cone
frequency response 28-1,000 Hz
power range 100-300 watts RMS
peak power handling 1,000 watts
sensitivity 85 dB
top-mount depth 5-15/16"
sealed box volume: 0.5-0.8 cubic feet
ported box volume: 0.6-1.25 cubic feet
Recommended Box Type: 1, 2, 3
1-year warranty
DETAILS:
Key Features:
sensitivity 85 dB
1-year warranty
Hey. The reason your probably arent gettin any hits is because you can get that exact subwoofer for $100 new at etronics.com. You might want to change the price.http://www.etronics.com/product.asp?...de=alpswr1041d
wingsfan19
15
Sep 2, 2015 02:15 AM
