FS: RSX Type-S 19mm rear sway
Hi everyone im from clubrsx, im selling my rear sway cause i got the jdm rear sway for my car,
i just joined the board because im sure i can sell it here, make me an offer, I prefer pickup only, dont wanna deal with shipping.
The part will be avialable for sale as soon as it is off my car, im planning to install the jdm one this sunday.
Thanks!
-Robert
p.s. my name is also neorobert on clubrsx for those of you who go in there
Thanks!
-Robert
brackets?? no just the bushings
to tell you the truth im not sure exactly which pieces u need to put this on your car, i just though it was a bolt on, so that all u needed was the sway + bushings
well i searched on here and this is what i found
Originally posted by ak
That's right.
Once again, for the millionth time.....
DIRECT BOLT-ON for the following:
01+ EX (All Models & All Trannys)
02+ LX (All Models & All Trannys)
RSX FACTOR is giving you EVERYTHING YOU NEED.
-Anti-sway bar
-bushings
-you can use your stock brackets
That's right.
-Anti-sway bar
-bushings
if you don't have a sway bar like the lx/dx/hx, then you need to get the brackets a.k.a. endlinks plus do some drilling for the bushings...
but if u have an ex (comes with rear sway stock), then its a direct bolt on...
Originally posted by Sickboy
Yeah I think you just need the larger bushings but I think your metal brackets that hold the bushings are a little bigger or stronger, not sure though.
RSX brackets are slightly thicker, but you won't feel a difference unless you upgrade your endlinks.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
ex2peria10
Aug 27, 2015 09:02 PM
