d17a2 engine swap into 95 hb
hello i was wondering how much conversion would be needed to put a 2001 honda civic engine d17a2 in my 95 hatchback.
i currently have a 95 d15b sohc vtec engine in there with a d16y8 port and polish head and all the natural aspirateds mods you can think of in there, i/h/e, clutch flywheel,fpr, 70mm throttle body, obx intake manifold because i can get one very very cheap and just thinking aboutn this, i also have some zc pistons can these work in that engine ? can i just use the bottom end of the d17 and put the d16 head on it ? or no ? i wanna build a natural aspirated minime setup
i dont think the d15b parts will work in the d17 motor. and it sounds like u have a decent motor right now, SOHC VTEC with some internals and boltons. why go to a SOHC VTEC motor that doesnt have many internals out for it and dont reponse very well to bolt ons? kinda sounds pointless to me.
I sure wish my car was newer
I'd rather stay with that D15 considering all you have done to it. If you're gonna go to the trouble of swapping, go with a B- or K-series motor. You'll be a lot happier with your results.
yeh im gonna just get a d16 bottom end then since everything i have can work on it and put the zc pistons in and create a high compression na monster with 12 or 13 compression ratio but i was just thinking about the d17 because i can get it much cheaper and it has 7lbs more torque
this might sound stupid.
but why?!
theres a reason why people are swapping our engines with k20s or boosting.
there are so many other engines out there that will be alot more cost effective.
but why?!
www.AbsouluteDriven.com
Honestly... our D17 nor will the K series fit under his hood. Its pointless to do the install anf if you would want to your dumb because for the same cash you can get a motor that will fit like a B16 or B18 and be 30 times faster!
oh yeh i have a stage 3 zex cam and a mugen ecu vtec 4700 redline 10,000 and port and polish head so much stuff i dont remember and i have beaten a few modified b16 and b18's and now im putting in high comp pistons so ive gone to far with this engine and i love it and dont have the money right now to swap to thats the story and thinking maybe spray like a 50 shot
Originally posted by BigFrank
not true ive seen a vid of a k20 inside of a 92-95 hatch
Re: d17a2 engine swap into 95 hb
theres like at least ten k swapped egs in toronto its not the hardest swap in the world to do. hasport makes mounts for like 500-600 bucks and its good from there
theres alot of sites with guys doing it just use google
look the d17a2 swap is point less belive me i have one, if you are going for the swap try to get a b18 or a b16 or a k20 but there are kind of expencive, you can fit anything into that engine bay i have seen j-series(honda V6) engine on 95 hacthback. they have one in youtube with a v8.futhermore, if you really want to kick some major *** with a naturally aspire engine try to get a b20 block from a crv with a b16 head.
look the reason why websites like this are done, is so can people can get inform about things that they dont know ,you knew it, but maybe the guy who start this the thread didn't, so please keep stupid comments to yourself .
it would only be worth it if your getting the b20 block for really cheap because you would have to swap out the internals of the block since the rods on the b20 are a lot weaker then the b18 and not be able to take advantage of the vtec head.
your better off just getting a b18c1 and boring it out to 2.0L.
but the last post in this thread is from 2003 I think the guy got his answer
and I was not talking about the b18 b20 I was talking about that this thread is from the dead TemjinX2 got what I was saying
back to whoring
cloudguy
Apr 28, 2015 05:02 AM
