PLEASE help, did I FCUK UP???
Old Nov 2, 2003
usafstud's Avatar
PLEASE help, did I **** UP???
i wanted to change the engine oil when i got home, i couldn't use my ramps or the jack(pumping) since i just lowered my car
so i used the stock jack on the left, but i used a jack from another car for the right, the other one didn't have a flat surface where it lifts the car
It had like a U shaped clamp
i started lifting the right side first, the clamp wasn't set on the lift area of the car flushed, i started lifting and the gravity dropped the jack rail down into the U clamp, when that happened, there was a loud CLONK, the car didn't drop, but the part where the two rails are welded together got separated
can u tell me if i messed up the integrity of the car, can i still road race it?
I'm going to Streets of Willow(road racing) in two weeks and I CANYON RUN a lot, do i need to
worry about this???
please help, should i weld the two pieces together
Old Nov 2, 2003
usafstud's Avatar
another
Old Nov 2, 2003
usafstud's Avatar
pic
Old Nov 2, 2003
usafstud's Avatar
can you all PLEASE check ur cars and see if you have the same problem?
Old Nov 2, 2003
Grey's Avatar
DIY King
No big deal. Your car is fine. The part that got seperated is a body panel; not some integral support member. It's just an oopsie and you should try to make it look nicer if you can.
Old Nov 3, 2003
CIVIKRACIN's Avatar
CIVIKRACIN is an unknown quantity at this point
I DID THE SAME EXACT THING ABOUT 3 MONTHS AGO WHEN I WAS ROTATING MY TIRES
U SHOULD BE OK
MY CAR FINE AND I DRIVE IT HARD EVERYDAY
1sykcivic
Jun 27, 2006 10:25 AM
Blkcivic
Jun 15, 2006 11:29 AM
