civic si sway bars better ?
Originally posted by CapYoda
01 and 03 and 04 are 12 i believe.
02 is 13mm.
honda was messing around with it.
02 is 13mm.
anyone, feel free to correct me if i'm wrong..
what i was to understand a sway bar does, is it decreases body roll, so your car doesnt lean (as much) during turns
Autocross Junky
Originally posted by 6_funk
i've tried a search, and i can't find a definite answer.
so can anyone explain to me exactly what a sway bar does??
thanks
thanks
sway bars AKA roll bars AKA anti-rollbars AKA anti-swaybars.....
Anti-roll bars are quite possably the best addition to cars since tires. They provide an excellent means for adjusting roll couple Distribution (Handling balance). they also control body roll, reducing camber change through corners. Of the two jobs that an Anti-Rollbar does, Adjusting the Roll Couple Distrobution is the MOST important. So just what is roll couple distribution? Simply put, roll couple distribution is the amout of roll resistance at the front of the car relative to the amount at the rear. Changing the roll couple distribution balance changes the handling balance of the car. If you increase the front roll resistance, the handling balance will change. If the car was neutral before the change, the car will now Understeer. If the car understeered prior to the change, it will understeer more, and if it oversteered, it will oversteer less after the change. The opposite effect occurs at the rear, where increasing rear roll resistance will increse oversteer or reduce understeer. The roll resistance can be increased by incerasing either the sping rates or the antiroll bar rates, or both. This makes roll resistance changes the key to finding a perfect steady-state handling balance. Adjustible antirollbars allow fin-tuning of the roll couple distribution making setup much easier.
more info on suspension can be found here
zcwagon
Apr 24, 2015 05:18 PM
jessepimpride
Nov 13, 2001 05:59 PM
CapYoda
Nov 11, 2001 05:17 PM
