Weird... 92 Octane really does help us...
Old Oct 4, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
For the past month or two, I have been experimenting with Premium fuel... I wanted to see if my gas milage improves... now being fair and driving the same as I always do.. each of the times with Premium, I averaged around 230-240 miles per tank, and w/ regular, I get around 190-200. The results were the same each time. Those figures were done with 3 tanks of premium, and 3 tanks of regular... I don't understand how this is possible??
Old Oct 4, 2003
Hondasport2k3's Avatar
i gOt da MaJik stiK
Hondasport2k3 is an unknown quantity at this point
hmm. that's pretty interesting. well the more money the more quality i guess.
Old Oct 4, 2003
Mr.Modify's Avatar
when you did this did you wait till you were completely on "E" because i thought you couldn't just switch up fuel like that going from like what is it i think 87 to 92?
Old Oct 4, 2003
opto_isolator's Avatar
Well - what have you done to your engine? It depends if you have raised your compression ratio or have carbon bulid up or something....
Old Oct 4, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
i myself have tried this many times and i get the same result it doesnt even matter if the car is stock i get the same results and i tell everyone but they say im wasting my money blah blah so i dont say anything anymore i just full up with 93 octane and i'll never put regular in my car again
Old Oct 4, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
only 240??? i always use 89 and i get around 350 - 400 per tank for the last couple months ( i thought that's allready bad gas mileage) ......... and usualy i get around 400-425 per tank
Old Oct 4, 2003
Try getting only 22-24mpg. I'm hoping new plugs will raise this.
Old Oct 4, 2003
MangoEX's Avatar
Just Be
i get those #s
Old Oct 4, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
Damn, those are pretty low #'s
Old Oct 4, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i think the numbers are ok 240/13gallon tank=18mpg 400/13gallon tank=30mpg, uh the mfg tag on the window in the lot doesnt even go that high. so maybe if ur running a honda insight or something i could see that happening but not in our cars
Old Oct 4, 2003
Numbers are not okay. The sticker says an average of 31 mpg city and I get 24? My 1987 Jetta got more mpg than the vic.
Old Oct 5, 2003
Civicly02's Avatar
iguess ot all depends on how hard the person drives their vic and also what kind of terrian you drive in (ie hills and valleys or just plains) also how fast you drive and other things
Old Oct 5, 2003
player's Avatar
isnt it untrue that the faster u drive the more gas u burn, because u r covering the same distance in less time?
it only depends on how u accelerate
Old Oct 5, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
same here...I usually get on average 340 to 400 mpg
Old Oct 5, 2003
maxsin's Avatar
No Title
maxsin is an unknown quantity at this point
on 87octane i get about 290 depending on how i drive... my max was 340
03 ex manual
Old Oct 5, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
I usually get 340-390 w/ moderate beatings (33-35mpg). But it's ALL highway. Octane level only matters per your compression ratio. More compression = higher octane. If you ran 87 in a high ratio motor it detonate. We run 9:1 max (stock ex) you don't need high octane.
Old Oct 5, 2003
nuffsed's Avatar
yah i did that same sort of test before... and found i got more mileage... but i don't think it really saved me any money using premium...
Old Oct 5, 2003
Bellz's Avatar
I'm gonna put in my 2¢ here. I've said it before, but my car ran like $HiT on 87 octane. It runs ok on 89, and seems to run great on 92. Granted, it takes the computer a while to adjust to different octanes.
You're got to remember that the civic isn't a sports car and doesn't act like it. Cars are made to be almost idiot-proof, so that people that don't change their oil, mix the gas quality,etc etc can't mess them up and cause the car to break down. Sports cars are different. They're MADE for higher performance, have higher compression, etc and have to be treated as such. However, they are also made to be idiot-proof to some extent. The point is that you're NOT gonna see big gains with small mods because the car isn't designed that way. The RSX IS!
Putting higher octane in a civic may give you better gas mileage, but most sources I've read say you probably won't even notice it. My own perception over the years, with many different cars, is that higher octane makes the car run smoother and does seem to give you a little extra boost in power. I've noticed it even on the civic. It only amounts to less than 2 bucks difference each fillup when the price difference is 10¢/gallon and you fill it up with 13 gallons. I'll gladly pay the 2 bucks once a week or so for a smoother running engine.
The way you drive the car makes all the difference in mileage figures. You can't drive it the same identical way for comparison, because of different traffic conditions, but you can average it out over a few tanks like
MangoEX did. So, I give you props for proper technique.
The other thing that will make all the difference is all the stupid mods that people have done to their cars. Spark plugs, I/H/E, big heavy wheels and tires, suspension changes. These things all contribute to your mileage in one way or another. The only true comparison is two identical STOCK cars. I doubt anyone in the thread has a completely stock car, so you can't honestly compare with any accuracy.
Even TIRE PRESSURE can change your mileage drastically and contribute to poor handling and traction. Don't overinflate or underinflate your tires. The recommended pressure is on the tire. Read it and keep the tires at the proper level.
Finally, if you're not getting the mileage figures that your car claims (ex. 32-38 on the DX/LX 5 speed), then you've either:
1. modded the hell out of it and it's getting worse mileage.
2. you have a serious problem with the motor and/or computer.
3. you're using lousy fuel and/or the fuel filter is clogged.
Old Oct 5, 2003
exe30's Avatar
exe30 is an unknown quantity at this point
a. Actually the recommended pressure is in the owner's manual. The pressure on the tire is usually the maximum pressure for the tire itself, and is not specific to the car it's mounted on.
b. Or the air filter is clogged.
While I don't want to discount Mango's results, I can't theoretically see how higher octane increases mileage - it's not like the car squirts less gas into the cylinders because of higher octane. Or maybe it does?
Old Oct 5, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
i use 89, drive VERY fast and aggressively, and get 32mpg.....AROUND TOWN! Maybe my car's just special or something. I mean, I do everything that would make it have less mpg, but i still get 32...oh well, im not complaining.
Old Oct 5, 2003
Bellz's Avatar
a. the tire pressure in the manual is for the STOCK tires. I was referring to ALL tires. And yes, the rating on the tire is the MAXIMUM pressure. You don't want to keep the max pressure in the tire. Several things influence where you should keep your tire pressure: type and size of tire, outside temperature and the weight/load of the car and how you drive it. If you want tire pressure info go here or any tire mfgr's FAQ section: http://www.discounttire.com/dtc/broc...irPressure.jsp
b. thats FUEL filter, not air. I'm not sure why you quoted it if you wasn't gonna say anything about it.
Old Oct 5, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i get 25ish MPG.. and i use regular 87 octane. so figure everytime i fill up i put about 10-11 gallons in and i have driven like 280 miles
Old Oct 5, 2003
jwalker87's Avatar
Bodacious Member
i still think that's weird. I usually only fill 9.5 gallons, and I get over 300 miles for that.
Old Oct 5, 2003
HondaLuver's Avatar
Its a celebration bitches!
i usually get like over 300 miles, but thats when i pushing it on the "E" sign is on. i fill up with 91 because my ignition coils only recommend 91 or higher.
1. i have modded the crap out of my engine
2. i drive like a maniac, my rpm is above 3,000 about97 percent of the time
3. i have a lead foot
Old Oct 5, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
I ususally got 28-30 mpg and I drive it hard. Now with a lightened fly I get 24-25 mpg and still drive the same, just a little bit faster.
Old Oct 5, 2003
Samari's Avatar
we have a 11gal. tank, not 13.
Old Oct 6, 2003
Obsidian's Avatar
Obsidian is an unknown quantity at this point
um...we have a 13.2 gallon tank. I've filled my up to 12.8 so if we only have 11 gallon then I don't know where my gas is going. I usually get 350 - 400 on mine just regular driving. I have an 01 AT. If its highway, I've gotten as much as 500 to the tank
Old Oct 6, 2003
Bellz's Avatar
Okay, just to confirm a few things, I looked up the specs on the tank and mileage on Edmunds.
Fuel Tank Capacity: 13.2 gal.
Range in Miles: (City/Highway):
DX/LX: Manual: 422.4 mi. / 501.6 mi.
DX/LX: Automatic: 382.8 mi. / 501.6 mi.
HX: Manual: 475.2 mi. / 580.8 mi.
HX: CVT Automatic: 462 mi. / 528 mi.
EX: Manual: 422.4 mi. / 488.4 mi.
EX: Automatic: 396 mi. / 501.6 mi.
This should confirm what myself and many others have been saying about where your MPG and range should be.
Old Oct 6, 2003
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
396miles for ex auto?! what! i get around 300, 350 if im lucky...
Old Oct 6, 2003
GreenNVicious's Avatar
Newbie
240? Damn dude, you running turbo or got aftermarket injectors?
