how much did your K20 cost you ??
ok for those few select members out here on the forum that have the K20 swap in their civ's. well i'm curious as to how much you got the motor for ...... i have a good friend that does motor swaps in his garage so labor fee isn't a problem. i just need to start savin up to get the money for the motor.
Search and Learn
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432491722
http://cgi.ebay.com/ws/eBayISAPI.dll...category=40931
stuff that you will need
K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
guessing around 4000+
- AC compressor
- alternator
- wiring harness
- ECU
solarpunk70
Apr 12, 2016 11:43 AM
Touge
Sep 23, 2015 11:19 PM
curaze
Sep 22, 2015 08:27 AM
