v-tech convertion
Samoan<^>(-_-)<^>Power
thats impossible. in order to move the hydraulic piston inside the rocker arms it requires oil pressure to push the pistons from the primary rocker arm to the mid rocker arm then into the secondary rocker arm. once theyre engaged it will basically activate the high rpm cam lobe
pichon = cant even spell vtec right so how is he going to pull of a head swap.. answer he wont he will just blow up the car and hopefully himself so that will be one less moron trying to mod a car..
krayziebonet4l = one of the few people on this site that knows what he is talking about
Originally posted by HondaLuver
hey Spider883 what about me
I wish I was asian
Originally posted by Spider883
yea u are right.. so not worth it... u have to remeber there are only two reasons the ex has more hp then the lx.. first the vtec does add some and the second is the compression ratio.. the ex has 9.9:1 and the lx has 9.5:1 .. and yes that does make a difference
I wish I was asian
best bet (only 2 so far, so pick one) -
turbo (sf, turbodiscounters, max rev)
OR
swap (k20a, k20a2, or k20a3, maybe k24 if anyone tries it in a coupe or sedan. it already fits into the SI mini-van)
OR
if you ever visit puerto rico u can go to carolina's speed way, or ponce speed way!! you will see some good engine creations there. if fact we have the best sincronized trans in the world its on a civic SI.
They might not be a joke... but wouldn't Logic tell you that Japan would have the best... since the cars are Japanese... I don't know... But if they are so gangsta... THEM *****Z IS MAD TIGHT, AND MO' PROPZ TO MY HOMIES!!!
honda_2k1; soy de guaynabo
As far as the oil line you dont need it. I have had the vtec head in my car for the last 6 months and there hasnt been a problem yet. The VTEC activates perfect and I have it connected to an rpm switch. If you need help with something PM me.
Puertorican in da house!!!
i would just like to quote what pichon pmed me today.. after seeing this im sure everyone here would like to help him
pichon
F(?K YOU AS(H0L3!
DID I SPELL THAT CORRECTLY?
F(?K YOU AS(H0L3!
Originally posted by infinite012
He misspelled all of it...
