Inconsistent Temperature
Hi All, i have bought an EXI at the start of the year and everything was going on well
until recently, readings on the temperature is getting veryn inconsistent. In a traffic Jam, the temperature will shoot up to HOT and i can feel that the engine will get very rough and
noisy. However, when the car starts moving consistently for a while, everything will resume back to normal.
When driving in the rain, there is also 1 incident that the meter goes all the way down to Cold, which should not be happening...i sent the car to my workshop to check, they have
changed my radiator fan and also taken out a thermostart (to be used in cold countries) but
the problem still persists.....anyone facing this problem before or any ideas whats happening to me car??
Do your fans turn on automatically like they should? If your in warm climate, you can just start your car, warm it up and then park with the engine running. Eventually the fans will start.
If I'm correct, the fans are told to turn on from the ECU once it reaches a certain temp. That temp is determined by the CTS(coolant temp sensor). So maybe check that out or just replace it. If your CTS is defective it'll tell the ECU to do all kinds of weird things.
It doesnt sound like its your waterpump or blown headgasket, but its possible. I have a temp gun that I use to tell the difference between the upper and lower radiator hoses. When the engine gets real hot, I shoot the gun on the hoses. If I dont see a temp diffference, its either a clogged radiator/coolant system or waterpump. I dont know if you can reach the hoses, but if you can touch them(becareful) you can do the same thing if you dont have a temp gun.
Could be your temp gauge.. doubtful but ya never know.
BTW, changing the thermostat to a colder one can cause problems as well. The ECU has been programmed to do certain things at certain temps, if those temps are never established your car wont run right. I'd go back to a stock thermostat at the next oppertunity you have.
Nope, the fan does not turn on automatically. Even when the temperature rises high, it still does not turn on. Thought that this may be the problem, had the fan changed to a new one but the problem still persists.....
Fuse number 4(20 amp) in the under-hood fuse/relay box, and number 14(10 amp) fuse in the driver's under-dash fuse/relay box. It goes on to read about how to troubelshoot these items that are related to the radiator fan circuit. You really should think about getting a copy of the manual. Best 100 bucks I've spent on my Civic. It talks about the fan relay, fan switch, ETC among other things.
Think that it may be the problem. Any advise on how to test the functionality of this sensor? In addition, where is this sensor located?
I think what he did was to take the whole thermostat out rather then changing it to a colder one....anyway, whenever i goes up to speed of 110km/h or higher, there is a very distinctive ringing sound that comes out..is it a sign that something is not going right??
raymondxcho
Sep 29, 2015 09:00 PM
david34
Sep 23, 2015 11:13 PM
Bruce2
Sep 21, 2015 08:01 PM
cizsak
Jul 21, 2015 03:39 PM
