Water/Alcohol Injection FAQ
Old Aug 4, 2003
iamboo's Avatar
Retired - SoCal FI Mod
I noticed a lot of people had questions about the water/alcohol injection... i search the net and pulled up an FAQ for you guys...
Water Injection Facts:
When increasing the boost level of a turbocharged vehicle, an undesirable byproduct is an increase in intake temperatures as well as a corresponding increase in combustion temperatures.. These higher intake temperature increase the chance of detonation within the cylinder. The best solution is to add an intercooler when the boost pressure exceeds 12 psi, but this is not always practical due to cost and packaging limitations. The early Chrysler TI (drawthrough) turbo engines are a good example of packaging limitations. It is somewhat difficult to fit an aftermarket intercooler to the factory manifold. This makes it a good canidate for water injection.
Water injection decreases the possibility of detonation by lowering the combustion chamber temperatures and increasing the effective "octane" of the fuel. This allows the engine to run a higher boost and full spark advance without the use of race gas. Additionally, if the water is atomized in the intake stream, there is an additional cooling of the intake charge. Both effects are increased with the inclusion of 50% alcohol to the mix (don't spray the exterior of an intercooler with alcohol!, this refers to internal injection only). The additional fuel of the high octane alcohol will in turn allow boost beyond what the factory fuel system can deliver.
Water injection also has the effect of "steam cleaning" the combustion chambers and exhaust valves. This removes the carbon build up that decreases efficiency and leads to pre-ignition(detonation). It will also keep the throttle body and interior of the intake manifold much cleaner than normal.
Water Injection FAQ:
Will water injection increase my horsepower?: Yes, but not directly. Water injection works to eliminate detonation, also known as knock. The big gains come from the ability to increase boost as well as the full ignition advance allowed by the ECU when it does not detect knock. While the cooling of the intake charge will produce some power increases, those increases are cancelled by the charge space occupied by the water vapor. In other words, there is slightly less room for air and fuel. However, by using up to 40 percent alcohol with the water, additional cooling takes place before the turbo, and the alcohol works as a fuel in the charge. This results in an increase in power.
Is water injection new?: No. Water injection was used during WWII to surpress detonation in fighter aircraft and increase their service ceiling.
Does the water "burn" in the engine?: No. The water simply converts from a vapor to a gaseous state which absorbs huge amounts of heat, due to the energy required to transform it.
What if my engine has an intercooler?: We do not suggest injecting water before the turbo in an intercooled application, as most of the water will condense out at the intercooler. However, our system works great as an auxillary sprayer to increase the efficiency of your intercooler. In this application, water (add ice if you wish) is sprayed on the exterior of the intercooler to carry away the heat. Simple, easy, and effective. Subaru WRX rally cars use the same type of sprayer on their intercooler (but I bet it cost more).
Do I need an extra "tank"?: No. Our systems are designed to use the original washer fluid tank (most have a built in level sensor), but you may choose to add a seperate tank which you supply. The alcohol/water mix actually works like washer fluid, so you can kill two birds with one stone.
How often do I need to fill the tank?: It all depends on how often you use the system (it's only active under high boost) and how big the tank is. Even the smallest tanks will last for 8 full 1/4 mile runs or so. In around town driving (racing?) a tank full should out last a tank of gas.
Info from: http://www.dawesdevices.com/water.html August 4, 2003
Old Aug 4, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
GREAT POST!
Old Aug 4, 2003
ironcow's Avatar
ironcow is on a distinguished road
so im confused...every time i drive, i need to spray the mixture
what if i forget?
or run out while im just daily driving
what if i want this turbo for daily and not race? is that not practical?
Old Aug 4, 2003
cdmx's Avatar
omg this is so cool...id sell my computer, my tv my printer, my desk lets see what else...my chair my lil fridge...for that kit!
wait what am i saying i still need the comp...but mabye not
Old Aug 5, 2003
cdmx's Avatar
so...Its injected into the intake manifold and is like a vapor and the vapor cools the air drastically?
Old Aug 6, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
yes. i set mine up the other day.... i adjusted it to come on only when the boost really kicks in... it's a stronger pulling sensation. lol. no really, i think it helps out.
you wont forget to use it because it is always on. it will only spray to where you adjust it to.
Old Aug 6, 2003
cdmx's Avatar
oh ok
Old Aug 6, 2003
RoBBUsaF's Avatar
blah. its been raining all day. i was going to make a diy but i guess it will have to wait til tomorrow. BOO
Old Aug 7, 2003
wavex's Avatar
wavex is an unknown quantity at this point
wassup wonderin where can i get that kit and how much holla back
Old Aug 8, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
what are the effects of running the W/A injection system and running a NX intercooler sprayer? would that help a bit more with making the air more dense? or is it just over kill and pointless?
Old Aug 9, 2003
lucky13matt's Avatar
lucky13matt is an unknown quantity at this point
how much is the kit???
Old Aug 9, 2003
RoBBUsaF's Avatar
an extra 100 bucks to the base price to the SF kit. 2900 plus 100 for that. but there are other upgrades as well.
Old Aug 14, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
So, with this kit you can run 11 psi safely on stock internals, right? But how safe is it for the motor in the long run?
Old Aug 19, 2003
RiceBuRNeR's Avatar
Turbo Member
How much for just the kit shipped? and since I have an air to air intercooler should I install it after the intercooler then?
Oh and is the mist of water harmfull to the intake air sensor?
Old Sep 18, 2003
Mikee's Avatar
Mikee is an unknown quantity at this point
good thread
Old Sep 19, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
$100 or so for the kit.. install is RIGHT by throttle body... loook at my rides pics to see... works GREAT.. wont harm anything because it isnt used consistently, and the mist is VERY small due to the turbulence of air coming through the intake at the speed it does...
Old Sep 22, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
does SF porer have a website yet? p.m. me
Old Sep 23, 2003
BoostedCivicZex's Avatar
Proud Srt4 owner
How much boost could you run with just water injection and no intercooler ?
Old Sep 24, 2003
So its safe to run 11psi with this right? But what can the fuel system take it?
Old Sep 24, 2003
Proud Srt4 owner
no one is going to answer my question???????
Old Sep 24, 2003
iamboo's Avatar
you could... it's called the poorman's intercooler.... it makes a bigger difference with the air/air intercooler tho...
Old Sep 24, 2003
iamboo's Avatar
it's safe to run it at 11psi... yes.... the fuel system??? what about the fuel system.... the alcohol causes your car to run a tad bit richer, which is a good thing...
Old Sep 24, 2003
oh ok, thanks!
Old Oct 28, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
um, is it possible to "run out" of the water/alcohol? ... if so, where can you get more??
Old Oct 29, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
yeah what kind of alcohol do you use? where can you get it? Can you set it to only use the alcohol if you turn your boost past like 6 psi?
Old Oct 30, 2003
RoBBUsaF's Avatar
just use rubbing alcohol
Old Oct 31, 2003
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
If you guys have access to uni chem labs you can just get some reagent grade ethanol/methanol (etc) and get some demineralized distilled water. Everything is pure and contaminant free. Especially if you live in an area that has very hard water.
Old Nov 1, 2003
GucciDaddy's Avatar
GucciDaddy is an unknown quantity at this point
check this out!
http://www.aquamist.co.uk/cp/sys1/sys1a.html
Old Nov 6, 2003
EnProceso's Avatar
the oringinal post didnt mention adding alcohol....so you dont always have to run water with alcohol, you can just run plain water?
edit- my bad it did talk about adding alcohol, but still, can you run plain water?
Old Nov 6, 2003
can you run plain alcohol?
