heatshield
It's easy.
4 bolts and unplug the exhaust manifold sensor and it comes right off.
Sand with 200 grit and wash with acetone.
prime 3 times and paint 4 coats and it looks good
Remember to paint your bolt ends to match.
Painted the plastic the same as the heatshield BUT took longer and more coats of paint (plastic sucks to paint).
Then used white tremclad paint (clings well) and hand painted the HONDA raised lettering.
Originally posted by 02civic
what kind of primer????? Is there a special type for high heat areas?
also, will washing in varsol do the trick?
1. 200 grit sand paper
2. 500 degree primer
3. acetone
4. paint (make sure it can handle 500 degree heat as well
whats acetone...isnt it like varsol..i've already got a bunch of that if its the same.
Originally posted by scansel912
damn that heat shield looks sweet, ive never thought bout painting that. how long did it take u to finish?
Primer and Paint applied in light layers for fast drying.
is 500 degree paint for the valve cover neccesary because i dont' think that part would get that hot because it would melt because its plastic. im thinking of using some model paint
is there a heat resistant paint???? NOT high Temp Paint ......... like there's a heat tape (like the one you wrap around the manifold/header).........
if there is one ....... where can i get it??
Ricerus Maximus
The plastic piece on the top of the engine, any paint can be used. For the actual valve cover, use high temp paint. For the heat shield, definetly use high temp paint.
Dash555
Aug 15, 2008 10:49 AM
mclean987
Sep 15, 2003 03:58 PM
