Help!!!!
Help!!!!
Ok so i put Mobil1 0w20 oil in my car today thinking all was cool (also put on a mobil1 oil filter) I lower my car down. Then my friends hope in and i go to back out of my driveway, but my exhaust gets stuck on a chunck of pavement in my drive (worst noise ever). so we pull the car up and jack it up to find there is water dripping from it (maybee from my mom watering). so i loosen the bolts on the exhaust then tighten them. and now i have water coming out of the muffler and the midpipe is hanging realy low. any idea's.....Anyone??????
Check the hangars, make sure you didn't pop one off. Water can be normal. If its really humid out, or you're running the AC, it isn't uncommon to get a little water drip out the tailpipe.
is it a lot of water? cuz if its just a little drip thats normal you probably dont know what your cat-converter does....The Catalytic Converter (commonly known as a Cat) is fitted in the exhaust system of your car to convert the following three gases for a cleaner environment
1)Carbon Monoxide (CO) converts to Carbon Dioxide (CO2)
2)Hydrocarbons (HC) converts to Water (H2O)
3)Oxides of Nitrogen (NOx) converts to Nitrogen (N2)
number 2 is why you see a little drip come out of some cars exhaust systems
