Transmission Gone OR CLutch GONE? HELP!!
Yah I Got 20K on my 2002 Civic MT EX. WHen i go up a hill and let go of the clutch it feels like its not catching right. Sort of a slipping feeling on my clutch foot. I dunno Whats Wrong Is My Transmission GOne or CLutch GONE already??! Please Help!
I think that you should check your engine oil level. If it is leaking oil then you should change your rear engine seal because oil is leaking out on the flywheel causing the clutch to slip especially on a hill because the engine is on a slope!!!!
I hope this helps!
I hope this helps!
Back From The Banned!
Originally posted by armieo
Kezay for someone who has only 7 posts, you sure know a lot.
Welcome to the site Kezay. Hopefully you'll be staying.
I hope this helps!
I hope this helps!
Great to hear the opinions however even though our engines are transversly mounted when we are on a hill the oil level becomes tilted almost to the level of the crank (By the rear engine seal) and it will leak out on the FLYWHEEL..... (The flywheel is hot that's why it burns off faster) Food for though!!!
And if you guys are like me then if a drop of oil get on my flywheel or clutch it will wear off in about 2-3 hrs (I don't hesitate to drag off. Sh*t whatever happens)
If you are at a stand still and drag off while balancing the clutch alot (somepeople say burning the clutch) it will slip a little when you go into 2nd gear!!
Try that and see.
Try that and see.
Also when the oil gets on the flywheel (which spins extremly fast) some splashes off into the sorrounding area before it could burn off. (And when I say the surrounding area I mean the clutch
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
FutureCivicOwnr
Aug 11, 2015 10:59 PM
