FS: RSX 19mm rear Sway bar (GTA pickup)
Old Jun 26, 2003
gone918's Avatar
gone918 is an unknown quantity at this point
Come with stock brushing, no brackets... $70.00
Available to pick up in Richmond Hill and North York
Old Jun 26, 2003
AznSaint's Avatar
AznSaint is an unknown quantity at this point
how long was it used for?
Old Jun 26, 2003
gone918's Avatar
I used for only 1 year....
Old Jul 1, 2003
gone918's Avatar
up
Old Jul 17, 2003
elmie's Avatar
elmie is an unknown quantity at this point
$60 and I'll pick it up tonight.
Old Jul 17, 2003
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
how much thicker is RSX sways compare to civic coupe ones ??
does it improve handling a lot ??
Old Jul 17, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Sunapollo, I installed mine like a month ago... it's an easy install mind you, except on the two ends where the bolts connect the sway bar. When you turn it, the whole thing turns and it gets annoying. Anyway, after install you definitely feel the difference. You can make sharper U-turns, handling improved and I find that the tail don't slide kinda anymore when you hit a bump.
As for the thickness, you can definitely tell the difference once you have them both in front of you. It looks alot more sturdy than the stock one too. One advice, when you install it make sure you put a fair amount of lithium grease on the bushings. The two piece that holds the bar securely to the body. You'll know what I mean, it's the metal piece that has a rubber piece that the bar actually goes through. When I installed mine, the dude I bought it from forgot to tell me right away so I lost one of the screws that holds the bushings. It's all good though cause the bar came with the screws that was used for the RSX and it fits just fine. Thanks R2Fresh!
If you need help with installing it, PM me and I can hopefully guide you through it, it's easy aside from those two screws, they were a bi*ch to remove.
Old Jul 17, 2003
maxEmus's Avatar
a.k.a incamus
maxEmus is an unknown quantity at this point
interested, is it still for sale.
Old Jul 17, 2003
CUE2k1's Avatar
Hey Maxemus, if you pick it up you can come install it at the same time as L23Tan... I'm gonna help him with it. My advise, GET IT! Well worth the money and for that price, you won't find one cheaper!
Just make sure it comes with the stock bushings and endlinks... if not, you can still use the stock endlinks.
Old Jul 18, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
amazing price, someone pick this up asap..... i paid double that for mine...... install takes less than 30 mins and all you need are a few hand tools...... in my opinion, the best suspension mod i've got........
Old Jul 18, 2003
maxEmus's Avatar
a.k.a incamus
Pm'd you
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
fordover
Jul 11, 2015 09:10 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
