View Full Version : Air Conditioning
- Air Flow Blocked
- 2010 Honda Civic AC Blown Fuse
- 2014 Honda Civic Heater Question
- Ac fan not working
- 2012 Civic Heating and AC problem
- 2009 honda civic ac bypass
- 2012 Civic SI A/C not blowing cold air
- 07 Hybrid AC woes
- Strange AC issue [solved]
- Need help 2012 Honda civic
- ac low pressure switch
- 08 LX 1.8L A/C blows cold and strong for 15 minutes and then blows cold and very weak
- 2007 Honda Civic Ex Compressor engaging and disengaging
- A/C clutch not working
- Issue with AC engaging and disengaging while idle.
- 2010 AC Pressure Switch Wiring
- '08 Civic AC suddenly not working
- Civic EX 2010 - AC condenser fan and compressor on at all times
- 07 Hybrid, No AC, no radiator or condenser fans
- A/C Compressor and Condenser Fan no power from relays
- AC problem
- Ac won't push cold air at idle. And whine at high rpm [solved]
- 8th gen A/C issue
- 2015 civic hybrid ac problems
- New Blower Motor Sounds Loud. Just the model? 2012 Civic
- Good non dealer Ac parts
- 2007 Civic Hybrid no A/C at idle, works at highway
- Hot air from vent - stuck air baffle help [solved]
- 2009 Honda Civic not taking in freon
- 2010 Civic AC not that cold and even more so when car is idle
- AC clutch jump?
- 2006 Civic AC Problem
- AC Problem?
- 2007 Honda Civic ac compressor doesn’t engage
- AC problem
- AC Clutch not working
- Complete new A/C & will not cool below 53°
- A/C compressor intermittent—relay swap didn't fix.
- AC Issue - Ideas to Diagnose other than Pull Evaporator?
- 2009 Honda Civic Hybrid a/c Problem
- big line at car hex sizes and tricks
- AC compressor hissing noise
- AC lights / AC it self does not work.
- A/C not working
- 2007 Honda Civic ex AC Air intermittently working
- Strange Heater Noise but not blower suggestions?
- 2012 Honda Civic Doesn't blow hot air.
- 2006 Honda Civic Ex Condenser Oil
- Weak Air Flow From Vents
- AC Not Working - Compressor not Engaging
- Ambient temperature sensor & wiring harness missing
- '10 LX A/C not working in warm weather
- A/C Clutch/Assembly Repair $$$ (2008 Civic LX)
- 2007 LX AC Clutch Barely Spinning, Squeaking
- 09 Civic DX-g 4d AC Pulley?
- AC Comp and Dry question
- A/C does not blow cool air
- AC compressor constantly cycling - 2012 Civic LX [solved]
- A/C Comp clutch not engaging. Full system replace need sensor voltages
- Defroster is blowing warm air
- Ac pressures equalized
- AC not working - help troubleshooting?? [solved]
- 2011 coupe dx electric fan problem.
- 2006 Civic without factory AC
- Ac clutch won't disengage
- A/c line freezing have pressure switch question
- Recirculating Button 2013 Civic [solved]
- 2014 civic ex AC noise in low
- Car won't take freon (2008 Civic EX)
- 2009 honda civic AC issues after 40mins of driving [solved]
- 2010 Civic vents/AC work fine for a short time, then seem to seize up.
- Fans and AC compressor turn on automatically when car starts causing lines to freeze.
- Weak AC
- 2008 Civic AC intermittently starts
- ac wiring help
- A/C Compressor
- 2010 A/C compressor will not engage
- Air con
- AC Compressor clutch does not engage 2015
- AC and Both fans won't turn on
- '09 AC clutch relay keeps blowing - common causes?
- 2006 Honda Civic AC Pressure Switch
- air conditioning on and off
- 2010 ac issues
- Complete AC Replacement
- 2011 Honda Civic A/C Compressor
- Ac not working.
- 2009 Civic AC problems help!!
- 2008 Honda Civic Hybrid A/C issue
- New A/C clutch not engaging 2007 Honda Civic ex
- Air conditioning COLD for about 30 minutes and then it slowly blows softer and softer
- My AC relay issue can any one help?
- Strange 2006 civic ac problem
- 2008 Honda Civic LX Air blowing hot air
- Heater hot and cold
- I need ac help please!!!
- AC Stopped Blowing Cold Air
- A/C Coil bad?
- A/C Mag Clutch Replacement
- A/C clutch?
- bypassing the ac compressor????
- AC not working 2010 Civic
- 2009 Civic LX AC Problems
- 2010 honda civic AC issues
- My AC is blowing hot.
- 2006 Civic EX - Low Air Flow
- 2008 Civic AC not always turning on
- Question on AC issue
- Need Help Troubleshooting Air Conditioing Problems
- 2012 Honda Civic EX - DIY AC Compressor Replacement
- 2009 LX 1.8L - A/C Compressor replacement
- 2015 Honda Civic ac blower motor issue
- New (to me) 2007 Civic AC not working
- HVAC troubleshooting- I've tried everything!
- AC compressor bypass belt diagram Civic 2006
- Civic 2007, AC weak cooling, now after injecting gas is cycling.
- 2010 honda civic fan and AC
- Intermittent A/C, but cold as ice
- 2006 Civic LX Sedan AC overhaul issue
- Serpentine belt
- 2014 Compressor Cycling 1.8 L
- 2006 Civic DX AC not working
- 2009 Honda Civic thermal fuse out again possibly for ac
- Climate control calibration
- 2015 Civic SE - A/C - Heat, Not Blowing
- Air Conditioning not cold when hot outside
- 2010 Civic AC not working. Please help!
- 2015 Civic EX - AC issue... Sorry if duplicate.
- Another ac related question(s)
- 2009 Civic, a/c won't work
- 2010 Honda Civic AC clutch not engaging
- 2006 Honda Civic LX 1.8 Condenser fan will not start
- 2010 Honda Civic Hybrid A/C Trouble
- My car shakes a lot when my AC is on
- 2006 Si 2.0 bypass a/c??
- 2012 Honda Civic - Heating Issue
- 08 EX Boiling bubbling sound from oil filter?
- 08 EX A/C Compressor & Fans Won't Shut Off
- a/c issue
- AC works intermittently on 2012 sedan
- Need help with air conditioner problem
- Rattling noise coming from front/front left of engine...
- 2011 Civic LX Ac problem?
- Help get pulley off AC
- 2008 AC Compressor Clutch Air Gap - Access?
- Heat Problem, blows cold on passenger side
- 2006 EX A/C issues
- AC Blowing cool - but not cold
- Is AC overcharged?
- A/C compressor clutch wont release
- Cabin Blower Motor / Fan " Repair " !!!
- blower problem
- AC goes kaput
- CAN YOU TROUBLESHOOT?cooling/AC fans run but not automatically
- 2006 civic a/c bypass help!!!
- '08 Civic LX Sedan, AC Compresser won't engage
- Ac compressor always on
- 2007 LX A/C clutch won't engage
- 06 AC problem Part II
- AC issues
- ac issue
- 06 AC problem
- 2009 Intermittent A/C Blower
- 2010 Civic EX
- radiater fan, ac-heater-defrost not working
- 2008 Civic EX - Defrost
- Very Poor Design for 2010 Civic
- Slow to heat up
- 2008 Civic AC Question
