PDA
View Full Version : Air Conditioning
  1. Climate control only blowing hot air
  2. No airflow from center vents
  3. No airflow from vents
  4. Leak in condenser
  5. heater issues
  6. 2004 Honda Civic LX 4 Door AC issue.
  7. I need help with my 7th gen AC!!
  8. AC questions
  9. Temperature door blend actuator help 2003 civic
  10. Usually what goes wrong, refrigerant lost 05 civic.
  11. A/c and e-brake light malfunctioning
  12. R134a refill question
  13. 04 Si(EP3) AC Compressor Replacement [solved]
  14. Freon question
  15. 2003 Civic Ex ac
  16. Are all EP models ac system interchangable
  17. AC issues/hvac codes
  18. Cooling fan #4 fuse keeps burning out
  19. Blower motor '03 Civic quick question [solved]
  20. Tried adding refrigerant but no fill [solved]
  21. Coolings fans not on when AC on [solved]
  22. what controls the heater core control valve?
  23. What should I do when heater doesn't throw off enough heat?
  24. Engaging Ac compressor diagnosis
  25. Low heat at idle
  26. No AC [solved]
  27. No heat and I'm stumped
  28. Foam cleaner on heater core? Evap drain location?
  29. PAG oil question Compressor, drier, condenser
  30. A/C Blows Cold but car jerks & engine vibration & noises
  31. 05 LX SE - AC clutch not engaging when hot [solved]
  32. Civic - Battery Drain on AC Circuit
  33. AC Troubleshooting Manual 2001 Honda Civic Coupe
  34. AC not working
  35. A/C Issue...any experts?
  36. 03 LX Fan blows hot all the time! [solved]
  37. Ac compressor harness wiring? Help.
  38. Faulty A/C button
  39. AC issue
  40. AC Normal HI & Low Pressure
  41. 04 Civic A/C problem
  42. New AC compressor or just clutch?
  43. AC making weird winding noise!?!?
  44. No heat until the thermostat opens
  45. Heater core installation
  46. 2002 EX A/C compressor clutch [solved]
  47. AC Compressor Seized--AARRGGG!
  48. AC issue
  49. 2001 lx vent select won’t change
  50. 2005 Civic AC cold on driver side not in middle.
  51. Help with A/C issue that Shop cant seem to diagnose/fix
  52. 05 Civic - AC Low @ 43 - High @ 50.... What does this indicate?
  53. Replacing Expansion Valve - Access through firewall?
  54. Need insight in my ac problem
  55. 2005 Civic - What do I need to replace with new compressor??
  56. Weird belt chirping [solved]
  57. 2005 Civic - AC not working...
  58. 2001 Civic A/C compress Bolt sizes
  59. A/C Pulley Bearing Replacement
  60. Wiring around heater core 05 civic
  61. Vent mode door actuator
  62. 2004 Civic Hybrid 1.3 A/C Issues Solved
  63. 2005 civic si 2.0 serpentine belt diagram no a/c
  64. Looking for an ac leak
  65. 02 Civic a/c condenser problem
  66. 02 civic Ac issue
  67. 3 wire vs 1 wire compressor
  68. Removing low pressure line to repair
  69. Diagnosing AC issues
  70. Cant remove ac clutch plate
  71. AC struggling with warm temps is this normal?
  72. 02 Civic AC is cold, then warmer, then cold again. What's my problem?
  73. ‘05 Civic a/c squealing sporadically when turned on
  74. Location of A/C clutch relay in under hood fuse box
  75. Loud leak only when air conditioning activated
  76. Where exactly is the heater control valve?
  77. 2003 Civic. 300,00 KM. No heat at idle.
  78. 01 civic ex a/c not engaging need help
  79. 2004 - Vents switch fine, but sometime Heat/AC changes and sometimes they doesn't
  80. AC system won't engage
  81. Lots of water dripping out AC drain hose with when AC is off
  82. 04 Honda Civic LX
  83. Intermittent AC cutting out
  84. A/C compressor not catching
  85. AC Compressor replacement
  86. 2001 A/C Warm
  87. Ac system PAG OIL
  88. Quick A/C question before i buy the compressor
  89. A/C issue need HELP
  90. AC high side 50psi, low side over-charges immediately
  91. PAG Oil Confusion
  92. AC problem that may be deeper
  93. blowing warm air everything else seems OK?
  94. a/c problem
  95. A/C System Flush
  96. Replace or Rebuild Compressor
  97. 2005 Honda Civc A/C turns ON on its own
  98. 7th Gen A/C ... great vid.
  99. AC Compressor Clutch Coil Test
  100. Ac will not take freon could someone help
  101. AC/Heat Vent Issue
  102. A/C blows warm 2002 Honda Civic LX
  103. 2001 EX compressor won’t kick on.
  104. NO Heat or A/C but Blower Motor still Works
  105. 2003 Civic A/C problem?
  106. 05 civic lx A/C refrigerant or oil
  107. Compressor belt squeal
  108. AC issues.
  109. I fixed my a/c compressor... in winter
  110. AC problem help!!!!
  111. A/C only works when you rev the engine to about 2500 rpm
  112. A/C not cold. Compressor runs, "hiss" in cabin
  113. AC Troubleshooting
  114. 2001 Civic LX - A/C blows hot air
  115. A/C Shuts Off, Gauges Drop, Sputters, Dies
  116. 2005 Civic/AC weak/not very cold
  117. 2005 honda civic dx ac compressor
  118. AC Compressor Replacement
  119. Intermittent AC
  120. AC compressor won't turn on - vents blow hot
  121. A/C problem
  122. AC cold when driving, warm while idle/stopped
  123. '02 Civic Si - No heat at idle.
  124. A/C works, Heater does not
  125. Is AC Compressor on separate belt?
  126. AC bypass? [solved]
  127. 2003 Civic a/c does not work
  128. blower problem
  129. 2003 Civic AC problem
  130. AC Issues
  131. Compressor Clutch Loud Click
  132. Belt squeaks when ac is on
  133. ezone - AC question
  134. 2003 Civic Si HB - Heater/AC fan not working
  135. Heater Core Problem?
  136. Evaporator drain
  137. 2002 Honda Civic EX AC problem!
  138. '05 LX heater/ac fan
  139. Heater issues.....
  140. AC Condenser - 2005 Civic
  141. A/C problem
  142. Heater problem - Civic 2003
  143. AC and Heater blower motor intermittant 2002 Civic
  144. AC Expansion valve location
  145. Air Conditioning working intermittently
  146. bypassing the ac compressor????
  147. A/C problem, filled it up, sounds better but clutch/compressor makes noise
  148. Defrost
  149. AC water in cabin
  150. A/C popping is normal
  151. Clutch issue at 57k??
  152. a/c not as cold as before
  153. A/C prob...
  154. AC issues
  155. A/C Compressor Won't Engage
  156. A/C with WHITE SMOKE occasionally
  157. AC DEFROSTER FEUL DRAIN
