- Honda Civic VI th Gen VTi Oriel 1.6 Analyzer Interface
- AirBag recall, with Quick Release?
- Odometer froze 1999 Civic
- Wiring Harness Question
- P3Y ecu immobiliser [solved]
- OBD2A to OBD1 ecu swap for tune not idling right
- Left turn signal doesnt work, sorta
- 1998 Honda Civic EX AT Starter clicks but doesn't start the engine
- Canadian 98 SI Cluster issues
- Honda civic EK3
- Clockspring Reel (98 DX)
- tachometer not functioning
- O2 sensor heater not heating, is my ECU to blame?
- 98 civic ex timing
- Wiring in an ELD (2000si b20b swap)
- Cluater of issues
- Erratic Speedometer
- 96 civic ex - D15b, p28 Ecu - Idles and runs bad.[solved]
- 1998 Honda Civic SRS Issue
- 1998 Dx temp gauge wondering.
- car stereo wiring help
- 2000 SIR Aftermarket alarm malfunctioning, car won’t start
- Vtec code p1259
- Factory Head Unit won't illuminate.
- Honda Factory security control unit
- Honda civic 2000 SR center panel
- Aftermarket stereo Troubles Help
- Fuel Pump wont prime and no start
- Gauge cluster lights, front driver's speaker: related?
- Weird speaker issue
- RPM gauge not reading correctly
- Ecm water damage
- b16 swap no start :(
- Radio won't work.
- CEL light from VTEC mini swap, ODB2 reader not reading
- Obd
- Headlight on = engine stutter
- new temp gauge reading about 90%
- Tacho not working on 99lx
- red light on dash??
- Engine misfiring after interstate run
- Honda Civic 1998
- Key Fob Mod
- Cant reset the srs light.
- 1998 no start-no injector or ICM pulses [solved]
- 1999 b16a ecu
- 2000 civic ecu
- RPM Guage not working.
- my rpm gauge is actin up
- ecu help
