View Full Version : Electrical
- 2006 LX Manual - Vehicle Speed Sensor (VSS) Connector Wiring
- Grounding
- Jumping the ODB2 port pins 4 and 9 while the engine is running
- EPS Control Unit Connector Part Number
- Cooling fan always on
- Dashboard lights too dim and reset button does not work. Is it run by a fuse?
- 2010 sedan ex horn comes on when key removed and stays on
- Intermittent problem with electrics cutting but car restarts
- 07 Civic Attempted theft ignition damage
- Slow Crank and then AC doesn’t blow
- Engine starts after shaking the battery [solved]
- Front passenger window regulator issue
- '06 clutch safety switch part #
- Fuel gauge doenst work post accident 2009
- Dreaded DRL System warning
- Civic 2013 No power on driver side low beam headlight
- 2014 lx fuse box smoking holds a...
- Horn doesn't work.
- Wondering what this connector around alternator is
- Parasitic Leak, 2015 Civic Sedan
- Low Power: Check Emissions System, VSA System & Power Steering System [solved]
- Egr issues
- Back up, lights problem.
- Pinout Procedure/Diagram 2010 Civic Wiper Switch [solved]
- Fog lights problems [solved]
- UO115 error codes / pcm electrical issues
- Electrical Issue [solved]
- 2012 Civic will not start. Newly installed radio and fuse 29 backup was blown
- 2013 ex cpe no power [solved]
- Power Windows Inop
- 2010 EX sedan dead stereo - electrical or stereo?
- 2010LX battery drains in a day [solved]
- 2007 Civic Fuse 19 keeps popping [solved]
- Low beam headlights stopped working
- Black ground wire from underneath dash
- Serpentine Belt 2015
- Poltergeist? Engine Started on Its Own!
- 2013 civic coupe
- 2014 Honda Civic | Radiator Fan connected with headlights??
- 2013 Honda Civic LX-Ignition module security bolts
- 2013 LX Ignition switch removal
- Power accessory socket
- 06 Civic oil/brake light
- 2014 Civic Ex - Driver's door unlocking whenever fob is nearby
- intermittent instrument cluster gauges failure + climate control issues
- 2006 Honda Civic LX 1.8L
- Dash light and dimmer
- charging system fail
- 2012 civic lx
- 1.8 Coil Pack Junkie
- No radio, no moonroof, and only driver door locks and unlocks by key
- 2008 Civic turn signal relay replacement
- '09 EX Random Horn Beep with Dash Light Blink [solved?]
- Blown Fuse for rear light causes non start ?? [solved]
- Door Ajar alarm will not stop going off (2012 Civic LX)
- 2008 r18 immobilizer question
- intake Wiring harness [solved]
- 2010 Blinker Relay Location
- Help identifying loose wire near cabin air filter (8th gen)
- Vsa power steering light code p2101
- Dashboard dims when I turn on the lights [solved]
- 09 Civic Ex Driver Side Brake Light Not Lighting (Not Bulb/Socket) [solved]
- 2013 Honda Civic LX - Which fuse corresponds to which light? [solved, kind of]
- Brake lights stay on when fog lights are on
- 2014 Civic EX Coupe LED Headlights
- Starter power wire touched metal now vehicle has no electricity
- 09 Turn signal flashing fast
- Honda Civic 2012 Locking/Battery issues
- Right headlight on 2014 Civic Sedan not working
- alternator problem?
- Mirror indicator lights aint working [solved]
- Econ Mode
- Amp draining battery, new alternator?
- Power locks stop working after driver side door slams open
- 2010 honda civic
- 2010 Sedan right speaker not working [solved]
- Rodent Damage-Cable Bundle Passenger Side
- 2006 LX Cruise Control
- 2012 Honda Civic Lx Electrical Issue
- Constant battery drain
- Odometer says “NO” on 2009 hybrid civic
- Unknown misfire?/ignition/electrical issue
- 09 Civ: drivers side DLR not working turn signal works
- (Civic 2007 LX) Driver side locks, the rest of the door locks stay stuck then open.
- Help! A chain of warnings. Where to begin?
- Civic 2014 died - for a second
- alternator? Battery? [solved]
- 2009 Honda Civic AC Problems to Green Key Light Problem
- MICU under dash fuse box Civic 2011 help?
- Climatronic lights, Steerwheel buttons backlight not working + B121 climate (europe)
- Battery Charging Mystery
- Civic 2011 Help! Location of Power door lock relay and wires [rodent chew wires]
- Folding mirrors only work when driver door is open (2007 ES)
- 2015 civic airbag light
- Headlight and turn signal flicker
- 2014 EX No low beams
- All the fans decided to quit at same time
- Battery Terminal
- 2010 Hybrid - Turn Signal/Hazards Not Working
- Trying to Diagnose Electrical Issue possibly related to output sensor(2015 Civic Si)
- 2015 Civic SI Electrical Shit the Bed (maybe just VSS but I cant be sure)
- HVAC control lights not working after radio replacement.... [solved]
- 2013 civic si issues after battery/sensor replacment
- no electrical power when ignition off - None!
- 2013 Civic LX with parasitic draw on Fuse 28 (Interior Lights) [solved]
- 2007 Civic, fuel problem
- Honda Civic Locked up
- Sun/moon roof not working
- Cheapest option to duplicate key
- Car Only starts when jumped. New battery and alternator. [solved]
- Instrument cluster
- Check Power Steering System
- 20063 Civic electrical issues
- Engine Died Suddenly While Driving, Cranks but Doesn't Start [solved]
- Dead Battery issue?
- 2015 Honda Civic Ex
- How to properly remove 30A fuse?
- Changing cabin fuse box - civic 2012
- 07 Honda Civic Key Won't Go To Position 0
- 2013 civic coupe dead in the water
- 2012 honda civic - power mirrors issues
- 2014 Civic EX - Window Switch
- Car won't start
- multiple warning lights
- Alternator Voltage issue
- 2012 Civic LX Sedan- 1.4L Automatic (NJ)
- 2009 Honda Civic Coupe Parasitic Draw [solved] - dealer GPS tracker
- door locking issues
- Re: Loss of power when attempting to crank
- Temporarily disabled alarm?
- Electrical Issue (2014 Civic)
- Erratic Charging Voltage
- 2013 LX Has Key/Lock Issues in Cold Weather
- Honda Civic IMA 2008 Navigation system
- 2006 Civic EX Turn Signals not "Clicking" Inside Cabin
- Flickering interior lights - battery or alternator? [solved]
- Headlight is unreliable. Maybe it's possessed..
- How to Disable 2010 CIVIC
- honda civic 2008 crank no start unless I manually ground PGM-FI Main relay
- 07 Civic 1.8L won't start
- Alarm dont work
- Power Window and Radio Mystery
- 06 civic trip reset/sel button wont change
- Fuse Tap on 9th Gen won't work
- 2012 Driver side tail light not working Brake lights fine
- Remote starter and FOB
- Fuse 29 and 31 Parasitic draw
- Door Locks not working
- Brake lights won't work
- Battery Starter Alternator Gremlins 2012 Civic [solved]
- Disabling the Civic 2007 SI trunk light
- 2015 civic si no audio/touch screen
- Car battery dead?
- Misdiganosis and unnecessary repair
- Intermittent no crank
- Reverse "back up" light bulbs
- 12v power outlet(cigarette lighter socket) How to make it constant 12v
- Honda civic heat problem
- parasitic draw on 2015 civic
- Battery keeps draining
- Intermittent battery drain
- help removing cooper connector for H1 bulb
- Question about light latch on Honda civic 2013
- Indicators/Flashers/Hazard/Parking light not blinking!!!
- Damaged Alternator Connector
- 2012 Civic EX - Car Will Not Start
- 07 1.8L TDC Sensor (Cam Position Sensor)
- continuously-running radiator fans killed battery. Solution?
- 08 LX power windows roll down without key
- Critters chewed my harness
- 2007 Civic EX
- Dimming lights and reverse lights
- Civic EX 2007 5dr 1.8 Battery draining
- Instrument panel dimmer control
- No dashlights, key fob showing red light
- Honda civic 2012 starts up, then shuts down.
- Ignition Key Won't Release
- Bad Parking Brake Sensor and Battery in Key on 09 Civic
- Dropping voltage when pressing the brake or at a stop
- Battery drain from AC Compressor Clutch constantly engaged
- Relay fuses
- A/C Clutch not engaging. Full system has been gone through
- Push Start wont immediately start car
- Honda Civic 2007 VMT 1.8 - Driver Door Doesnt Lock using Remote Key
- 2013 Civic Check Airbag System
- Brake light question (both then third out) [solved]
- No Green Key, Clicking Sound from Dash...No Start [Solved]
- 2006 honda civic ex coupe
- Car Won't Start, Battery Still Has Power (Remote Works Perfectly Fine) Any Ideas?
- Sunroof stuck
- 2007 Civic DX Intermitant no start/no insturment lights issue
- Stone Dead Battery - '09 EX-L
- Battery problems!
- Radio Display Issue
- 2006 civic 2.2 cdti electrical problem
- Ignition mystery
- 2008 Hybrid Battery Fuse
- My Honda civic 2007 flashes green key light and then stop some minutes
- DRL light
- No crank no start - but only when cold 2010 civic
- Help choosing the right harness for double din conversion
- 2010 civic “ticking” sound from dash when car is off
- Window Regulator Help
- My door power control switch’s lights won’t go off..dead battery
- Alarm not engaging/No Hazard flashing/ No power when key off
- Fuel gauge calibration
- Metal clip retainer Honda Civic 2015 (H7)
- 2011LX mph number display flickering
- 2007 civic ex sedan door lock/ battery dying issue
- Moving with IMA battery removed
- 2009 Civic LX - newbie help?
- Rear defrost
- Turn Signal Relay
- 2007 civic ex sedan door lock issue
- Parasitic Drain... I guess
- Honda Civic beeping
- 08 civic dx changed radiator fan not working. Plz help!
- Crazy electrical issues
- 2008 Civic electric trunk release not functioning
- Honda civic hybrid ac compression installation
- Low Beam left side out
- Drl module location
- Why is Inline Fuse Always On?
- 2006 civic battery drain
- No Horn. Need ckt diagram for horn ckt 2010LX
- interior fan motor won't run when hot
- Buying a new battery
- Headlights stopped working on my 2010 Honda Civic sedan
- Need help with accessory electrical circuit
- 2007 Civic - Battery Light Came on Then Car Dead in 30min (Code #61)
- 2006 Honda Civic 1.8l battery light was blinking then car died
- Reverse / Back out Lamp replacement
- Digital Speedometer dimming
- 2015 Civic Si Brake Lights Issue
- How long to run to keep battery from dying per week?
- 2010 civic blinkers and hazards not working. Help!
- Sometimes car acts like key isn't forward
- Battery Not Charging Correctly
- 9th gen civic tourer front door central locking issue
- Honda civic 08 AUX
- Using battery of honda civic 2018 turbo to start Honda civic 2008
- 14 Civic EXL randomly going dead and door lock issue
- 2014 civic wiring help
- Car doors won't lock
- No Start No obd2
- Inj and ign relays no ground pulse when starting ??
- Car dies then comes back on idle
- Head Unit and Gas Gauge won’t turn on
- 08 Civic slow crank wont start
- Key fob
