View Full Version : Transmission
- BMXA Shifting Issue
- Manual Trans Pops out of 2nd gear [solved]
- Em2 coupe
- Drive not working
- TCC code : p0740
- Don't know what transmission fluid to use
- Transmission issue
- malfunction indicator light caame on
- shift assembly in 01 lx is breaking
- Trans not working!
- Weird sound whenever I coast while in gear
- only goes into reverse
- Civic 2005 1.6 Noise
- Whining and ticking noise when accelerating in first
- 210k mi. 2001 EX sluggish gear shifting
- Clutch is building no pressure
- 2001 lx manual shifter fix broken shifter bushing
- my automatic transmission is having issues
- Dw-1 Alternatives??
- Doing an auto swap on my sister's 2001 VTEC, can any 4 speed bolt up?
- What is the name of this solenoid?
- Bad clutch? Or seized pilot bearing? [solved]
- Transmission delay
- 02 civic ex jerking!!
- New (remanufactured) transmission won't go into reverse
- 2004 Civic Si(EP3) CV Axle Length? [solved]
- '02 Civic auto trans mechanical noise
- 04 Civic, trouble bleeding new clutch hydraulics
- DIY manual transmission drop question
- What extra parts to get for clutch replacement?
- 7th Gen d17 transmission
- Input (mainshaft) sensor location 04 Civic DX [solved]
- Clutch/Shift Level
- Rebuild failure😢
- Flood water in transmission
- Push it to the floor to start
- Help! Is my transmission damaged?!
- Torque converter clutch solenoid for 05
- Transmission??? Or something else
- Shifter hard to engage into first and second gear (MT)
- Torque specs
- Transmission compatibility
- Hybrid AT sudden failure question?
- Please help!!! 4th speed sensor that wont stay in trans..
- 2002 Honda Civic (Automatic) Intermittent shifting Issue
- Exedy bearing looks wrong
- 2003 civic automatic transmission slipping.
- Only 3rd and 4th work after taking apart transmission. (Manual)
- 2001 Civic Lx transmission issue [solved? cause was trans]
- Torque converter
- Engine not starting after Trans Swap
- Noise Civic 2001 standard
- manual tranny, vaccum line? [solved]
- 2001 clutch line
- BMXA inspection question
- JHM vin, on 01 civic, jdm trans compatible?
- Help to diagnose my noise problem
- Torque Converter lockup in 2005 EX AT
- transmission issue but car still runs (barely - AUS car)
- Replacing Driver Side Axle?
- Issues after driving through high water
- Transmission Cooler Hose Size?
- Help. Civic is popping out of 5th gear. [solved]
- New leak after oil pan [solved]
- 1st Gear Delayed Shifting (automatic)
- I can't figure it out plz help
- 03 EX Differential Speed Gear interchange
- My trans is shot isn't it? Where to get another?
- Manual tranny rebuild
- Torque specs
- Car starts while in gear
- Is this the sign of a bad input shaft bearing?
- 2004 LX 5 Speed Manual Won't Move in Neutral [solved]
- 03 civic ex 5 speed problems
- Difficult to shift into 3rd and 4th
- Help identifying this plug in trans
- Clicks in park
- Rebuild Kit for 5 speed manual
- metal on metal sound
- Transmission problems
- Clutch line was replaced oh, but still erratic and pressing down
- What clutch kit is best for my ride [solved]
- 2005 Honda Civic. Vp
- Clutch bleeding help
- Compatible manual transmissions for Civic
- Shifting Issues/ Shift Flares SOLVED! 2003 EX
- Transmission engages but wont spin axles
- bad vibration - CVT trans
- Manual 5th gear issue [solved - with replacement]
- A/T Gear Shifter Noise - ‘02 EX Coupe
- 7th gen , '05 civic ex A/T lockup solenoid
- 2005 LX Manual- Transmission Problems and Next Steps
- P0796 Shift Solenoid; Pressure control Solenoid C
- Time to bite the bullet
- Clutch not working
- Manual trans hard to shift all gears [solved]
- 2005 Honda Civic EX Coupe
- Axle improperly seated?
- 2005 Honda Civic lx auto transmission not getting into gear
- Car pops out of 2nd gear when turning
- 2002 Honda Civic Automatic Transmission Reverse Light Switch location
- Clutch is slipping is there any kind of adjustment on a hydraulic clutch
- removing transmission
- 2002 Honda Civic Manual: Stopped Accelerating on Freeway
- engine poorly supported help!!
- a few questions while doing clutch job
- RPMs going up but car isn't accelerating
- the wrong kind of burnout?
- 2005 Honda Civic EX Coupe Auto Axle's Stuck
- p1773
- Code p2770
- Car running slugish
- Tips or tricks on slipping clutch
- Swapped transmission now it wont start
- 7th gen , P0722 replaced sensor
- Newfashions
- 2002 Civic JDM transmission question
- New clutch master cylinder not accepting fluid from the reservoir...
- Honda Civic 2005 manual transmission front right engine mount
- Clutch pedal sticking to floor... [solved]
- Got mad and was repeatedly stepping hard on my clutch now pedal won't come back up
- 2001 Civic P1768 and P1773 trouble.
- After Tranny Swap Issues [solved]
- Non-oem transm mount w/out weight can cause idle rattle? and mufflers
- Manual clutch bleeding 2003 civic ex [how I did it - information]
- Transmission
- P0722... on my '05 civic lx sedan
- Help with 05 civic auto transmission issues and install
- Shifter stuck
- 2005 EX SE Manual Trans Noises
- Civic - RSX compatibility
- 2003 Civic EX won’t go out of park
- Re: 2003 Hybrid Transmission disassembly
- Droning sound from rebuilt manual trans
- 2001 civic axle nut
- drive axle quality and options
- My cv axles won’t slide into the differential [solved]
- Are my SLW diff bearings supposed to be packed with grease?
- 2004 Civic, Std trans, popping back into neutral at top gear
- Can I change clutch fork without removing transmission
- 2004 civic auto tranny peoblem
- question about transmission
- Tyler method for 2004 has it worked?
- 2005 CVT repair options
- Common manual transmission failures?
- Bmxa rebuild/diagnostics
- NSK or Fujikoshi throw out bearing?
- 2001 ex 5 speed tranny problem, and more.
- BMXA Loud squealing noise
- Will all manual axles interchange?
- 2001 civic lx
- 2004 Honda ex coupe shift linkage DIY
- What could be causing this sound?
- Did I break my shift fork? [solved]
- 2005 Honda Civic Tranny Issues
- Car shakes when letting clutch out
- won't shift into 4th gear
- Rebuilding trans, EP3, need some advice
- Engine Revs when accelerating but car won’t move
- D17A2 5 speed transmission rebuild
- 01 civic manual very loud grinding sound
- 2002 Civic EX Clutch Master Cylinder Removal
- P0740 code [solved]
- Improving clutch pedal feel (2003 coupe D17a2)
- Car cannot recgonize park
- What is this noise?
- Clutch Pedal Stuck to Floor
- 2001 Civic 5 speed grinding in gear only under load.
- Acceleration/transmission issue
- AT/T disengaging noise when slowing down.
- 3rd and 4th - engine revs between them when cold
- 01 honda civic ex (5sp) shifter broken
- Torque Coverter Bolts Sheared
- Does the EX have the NRH3 or SLW?
- Gears not shifting easily after a clicking sound
- Car runs but won't shift into gears!
- stiff shifter [solved]
- 03 civic lx automatic shift revving when cold.
- Clunk when shifting into reverse from park. 2004
- Has anyone Converted Clutch Hardline to an alternative?
- Won't shift into fifth gear
- Clunking noise on Low RPMS
- New clutch cant go over 3000 rpm without slipping
- I have no idea how to get the clutch line back in.
- What is this Plastic piece inside transmission called?
- Locked out 1st and 2nd, Troubleshooting inside of Transmission.
- Master Cylinder Connector stuck on hydraulic line
- One CV axle works but not the other.
- White dried pasty substance on Clutch Master Cylinder?
- Does anybody know anything about this part?
- The Honda Slave Cylinder Bleeding mystery!
- ‘05 Civic manual transmission fluid
- Where to buy a good low mileage transmission
- Water flood can cause transmission problems?
- 2003 Civic/BMXA Flares on Shift
- 2004 civic hybrid does move when in gear and clutch released.
- Hard time bleeding clutch
- 2005 automatic transmission grinding noise
- Need a clutch alignment tool, but dont know which one to get
- 2002 Honda Civic Ex- Bad transmission slippage through all gears
- Weird Noise / Hard to use gear selector
- 2005 Honda Civic hybrid 1.3 L Transmission issue
- Clutch and shifting problems after replacing axle seals.
- Transmission Lines -- Which is the Return
- 2005 Honda Civic Hybrid Missing Part
- LX Civic Transmission
- Replacing transmission
- New to my 2002 EX automatic - maintenance questions
- Pops out of 5th
- Shi
- The first thing that comes to mind please...TIA
- Shifting problem help please
- Transmission fluid dark and Dirty
- 03 civic manual clutch release fork bent
- trans
- Transmission
- 02 d17 Won't shift into second. New clutch, new syncros
- Noise on deceleration from trans/clutch area
- D - seriuse clutch
- Trans cooler lines
- Automatic shifter letters not illuminating
- Clutch replacment
- I think my clutch is done
- What clutch to buy for 2002 1.7 el?
- Cant remove aftermarket shift knob?
- Clutch
- Clutch Soft-Gear Grind-Cant Find Slave Cylinder?
- Rumbling on decel
- Clutch not working.
- 2002 CIVIC Auto hunting?
- Hard to Shift out of 3rd gear
- Clutch kit system
- Manual transmission is leaking fluid somewhere.
- 03 Civic LX won’t move
- Shift solenoids failing only when hot
- There is something wrong with my torque converter?
- Transmission issues
- Transmission rattles loudly at the very end of the bell when AC is on
- 2005 auto trans reliable?
- Slipping clutch with ac on?
- Manual tranny fluid 2004 Civic EX
- Oreileys sold me some axle seals and just looking at them, they're too big
- Leaking transmission fluid.
- Assistance urgently required.
- Code p0741 fix
- Stray Metal piece found in flywheel
- AT not going into gear
- 2004 hybrid with a manual trans... leaking. Think it's the axle seal
- New clutch stopped working after 1/4 mile
- Manual trans... popping out of 5th gear into neutral while driving
