View Full Version : General 6th Gen
- Help identifying Honda model [solved]
- Does anyone know what kind of civic this is ? 1999 2 door hb with 1.6L canada
- Door trim panels
- '98 with 240,000 miles - worth buying?
- New to Honda Civics
- Evaluation of 98 EX coupe
- 2000 SIR that doesn’t run value?
- Found this on offerup, thoughts?
- What is it worth
- Buyer Guide
- Buyer Advice
- I hear the 1998 is the best, but the other years have the same engines. Why is this?
- Manual 98 EJ9 with automatic dashbaord?
- What is this? Can't identify
- in the market
- Cranks but won't start. No check engine light.
- New member new civic
- 97 Honda Civic (auto)
- What Parts can i use in a 99 Civic SE
- Trying to buy another civic, but know nothing about LS VTEC. help?
- Newbie help needed
- What ecu should i look into for my civic build?
- I have a question about the d15b vtec engine
- How would I be sure that a seller hasn’t cleared OBD codes?
- first car HELP
- Windshield size for 96 Civic
- 96-00 dash changes
- 1997 Canadian Si?
- How Much Is My Dad’s Car Worth?
- 1998 hatchback cx as first car??
- Buying an EK9
- Civic 99 1.8 VTi
- Common issues to look for when buying a 6th Gen Civic
- Honda Orthia Mod/Upgrade Compatibility
- 1998 Civic with leather interior????
- How to disconnect horn & find repalcement?
- Need help for a Civic for sale
- Question about selling my 2000 Honda Civic Si - 79k miles
- Help out a new member with some advice
- 6th Gen Civic Buying
- Thoughts on this Civic for sale?
- D16y7 long block anyone???
- Reliable Mechanic in Melbourne
- Compatible Parts for 1995 Honda Civic dx
- Blue Light
- 2000 Civic SiR (EM1) Exhaust System Swap
- Best Oil for 1999 CXi EK1
- First Honda
- EK Value
- Need OEM passenger door any sites or recommendations?
- Need some help getting my first car!
- New Here- 1998 Honda Civic DX
- Average Price
- buyers guide
- Looking for first civic need advice.
- my 97 civic is coming along.
- D16y7 manual conversion
- Need help is this a honda or acura
- Is the 96 hatch (dx i think) a good buy?
- is this 98 civic a vtec
- How much $$ is 99 Civic si bra worth?
- feedback requested on buying a 2000 civic LX
- where's waldo?
- How long does it take?
- Is 6th gen forum still active?
- Fender with fender light
- 99 Civic Si Worth
- A/C trouble.
- New
- Auto Transmission Dipstick Very Loose
- '98 MPG - What's Normal?
- Swap or build
- 6th gen - Most reliable engine ever built?
- This is the year for the turbo kit
- Was a 2000 a 7th gen D17?
- how to find which parts are compatible for 1999 civic
- Did transmissions shift linkage bushings today - very noticeable difference
- seat interchange
- 1996 Civic Timing Belt Question
- Coolant drain and fill
- EK4 Auto AC Temp Sensors
- Different oil pans?
- 98 coupe dx,ex,hx
- How's this part called?
- wind noise?
- Question of cars value?
- Compatible parts for a 98 civic ex
- Starter Kill Relay
- Is my mechanic playing me dirty?
- Belt tension
- B20B civic hatchback
- Do the door checks, stopper, hinges have correct sides?
- Looking for any help figuring out what's been done to my 2000 Civic EX
- Some rust problems
- New to honda I just picked up a 1996 Dx hatchback with the non vtec engine
- 1997 honda civic ex trunk woes
- 1996 Honda Civic LX 4 Door
- 98 EX coupe - Driver side latch/actuator
- PIAA Wiper Blades
- Noobie Question
- 97 Civic DX manual, wont go in gear
- Traditional automatic or CVT automatic
- Cheap but good exhaust systems
- moving 1998 Civic from NY to CA - Smog Questions
- Need help buying ac bracket for compressor.
- 98 Honda seat belt problem
- Need an opinion on 97 Civic
- MPG hit when using A/C?
- I found this!!! EK 1999-00
- Is this a sound purchase?
- Well, I was hoping for an easy fix
- Buying a civic with high mileage
- Exact Civic Model
- First Civic
- First Civic, Question about a bumper.
- 1997 Honda Civic HX 5 Speed MT Engine Wiring Harness search
- vehicle collision, looking for under hood specs
- 800 dollar EK Hatch
- First honda civic
- Need help on this part, any advice would help!
- HELP! Seized engine ?
- Piece of rubber inside radiator.
- What is this cylinder? Honda D16Y8 engine.
- d16y7, d16y8 engine block interchange
- DIY: How do I tell if my 6th gen Civic has a vtec or not?
- Help! Rear Bumper part (Sagging bumper) 00 Civic Si
- Will a 96 accord front clip fit on my 96 dx coupe?
