- Headers
- best sounding Exhausts for 6th gen civics
- 2k dx question
- exhaust flange questions
- Exhaust help!
- 98' dx hatchback ecu tuner
- New Exhaust 99 Civic EX [solved]
- What header can fit my d16y8?
- D16Z6 intake manifold on D14Z2
- CAI's
- A/C and Power Steering delete
- B20 more power
- Does an Apexi WS2 catback exhaust fit a b16b?
- 1999 civic exhaust upgraded info need help
- Best civic aftermarket exhaust
- Honda civic ex 20000
- Xtd clutch kits
- New Intake and IACV
- Yonaka exhaust header options
- Can a cold air intake and catback exhaust blow a head gasket?
- skunk2 Tuner Stage 2 Camshaft - D VTEC
- Another exhaust post
- Hornet Class Racing Upgrades
- How to make my ek coupe quicker without going forced induction
- B16 non vtec with a 135,000 miles stock engine
- Downstream o2 sensor with straight pipe?
- Rust bucket rebuild
- i own a 98 civic ex 98 4door sedan and was to swap in a d16y8 with a z6 head
- Exhaust For d16y7
- Cheapest bolt on for the most power
- Best engine replacement for a 1996 dx coupe
- 20w50 in a d16y8 1998 with 130 000 miles.
- Which Engine model is this?
- Need more ponys!!
- 98 civic belt question
- 98 civic EX issue
- Quick easy hp for circle track build
- Pinging despite correct plugs and timing
- Catback exhaust?
- Performance Build 97' DX Hatch
- Rough idle 97 Civic
- Pigtail Intake Air Temperature Sensor 1999 Civic
- Maximize 2000 EX potential on a budget?
- Aftermarket Header With Stock ECU and O2 Sensor??
- upgrading rusty
- help with my d series build
- lightweight crank pulley
- Short block replacement. D to B?
- D16Y8 in civic hx?
- AC Compressor - need help on the part
- Basic upgrades to stock D16Y8s
- Will this Skunk exhaust fit my Acura EL?
- Exhaust System
- boosting a stock d16y8
- Full exhaust
- Does 92-95 OEM muffler fit 96-00?
- Should I run a cat or a straight pipe with my new headers and exhaust?
- Any exhaust systems/headers worth a darn?
- Headers
- low oil pressure/ fuel pump shut off
- What are ALL the necessary things to do when doing a tune up?
- Throttle problem
- Stage 1 cams? For 97 Civic Ex Help?
- clutch kit
- what else can I do when changing timing belt/water pump?
- Rev limiter
- D16y7
- How much gains in low end by going back to stock intake from AEM CAI?
- 1998 Hatch headers and exhaust
- Exhaust help
- Exhaust Manifold/Cat Replacement - 2000 Civic DX
- Exhaust Shield Hottest Temperature?
- HELP with N1 spoon catback replica
- Raspy Exhaust
- fuel psi
- cant decide next step for mod- 96 civic ex
- starting problems
- Non fart can suggestion?
- Spoon & Hasport Mounts EK3 B16a
- 98 LX 1.6L SOHC Header and Cat
- Exedy clutch kit/flywheel
- what clutch to go with 97 cx
- 00 Civic DX w/ B20Z2 Exhaust question
- new with the civic
- Dna
- 96 ex 5 speed trans question
- Intake Manifold - Question
- What kind of short ram system is this
- 99 Civic HX muffler help
- Battery Light ON
- 99 Civic Si headers
- Transmission swap questions???
- vtec??? b18c1 swap boosted
- Tri-y header
- D16y8
- Newbie and need advice on what to do for first mods.
- Well, noob looking for a list.
- Idle problem with 2000 Civic EX
- possibly a thread already. Si exhaust & header choice.
- '98 Civic Engine Swap
- Exhaust Manifold DIY ??
- Rod bearing cap d16y8
- Need help with my aftermarket headers
- 00 Civic Si Intake and Exhaust install. What else do i need?
- O2 Sensor
- Exhaust Questions!
- Catalytic Converters/test pipes
- What distributor cap and rotor for 97 HX
- 00 ex civic upgrades help
- Test pipe d14a4
- whale intake
- Want new exhaust
- 96 Dx mini me swap questions
- what motor is in a 95 civic
- anyone have flywheel removal diagram for an automatic
- Skunk2 exhaust installation (need help)
- Ebay header wierd noise?!
- Intake Questions!!
- skunk 2 cams
- civic si cheap mods
- 1997 Civic DX swap aftermath
- Exhaust pipe change out
- honda engine performance
- Intake -Stock to Icebox
- Possible Existing Thread (Exhaust Selection)
- best fuel filter for D16Y7 1998 civic DX
- exhaust system help needed!!!
- Power Mirror Button Broke Off!
- Whats the best ram intake for my civic
- Things to come!
- 97 LX exhaust system nightmare!
- Replacing the clutch
- Fuel Filter Importance
- d16y5/Intake
- 2000 ex coupe exhaust
- Question about headers on a 98 civic lx
- Suggestions for my 99 LX
- D16 built need help
- Swap 93 exhaust to a 98 will it fitp
- Idle problem, Air control valve help.
- I need help.
- New Exhaust Is In But Too High? Jerry Rigging Help!
- Good replacement exhaust
- help!!!!!!
- 2000 civic si questions
- Should i decat my 99 civic?
- Cold air intake? Dual exhaust?
- About $715 to play with...
- Intake manifold and throttle body issues.
- 98 DX setting up for drag, any help with mods?
- 2000 Civic LX: Recommended Water Pump & Timing Belt Kit?
- ECUs and CHIPS where to get and what to get?
- New Engine
- Downstream O2 sensor
- Intake: Ram air VS. Cold air?
- Changing oil for the first time. Need opinions.
- swapping my d16y7 to a d16y8
- Is it compatible?
- missing power especially in higher gears 97 EX
- Spark plug upgrade
- engine fan problem??
- D16Y7/Magnaflow 15642 exhaust installation
- 98 civic dx, what mods should i do?
- Cooling. How to stay cool.
- New question
- Hatchback exhaust to coupe extension question
- Header heat shield question
- took off all emissions
- Y5-Y8 cams
- 97 EJ8 intake/exhaust hopups.
- Exhaust questions
- VTEC Conversion Kit
- Suggestions for cracked header / D16Y7
- Stock
- 98' civic LX automatic "mini project car"-new to site
- Help with mods
- can i change the location of my catalytic converter
- ignition system help.
- Best Spark Plugs
- Greetings and Exhaust Fastener Q's
- Ring Clamps Wont Stay Tight
- Want to get Catback exhaust - what size do I need?
- tune up/basic performance questions
- Quiet Axle Back? Aftermarket drone...
- need answers for choosing aftermarket muffler that is loud and deep
- How to quiet my exhaust
- INTAKE?? 97 Civic EX D16Y8 Auto
- Best Affordable Exhaust
- Ex y8 header/exhaust on Hx y5?
- New Member
- aFe 31-10032 Air Filter question...
- Z6 Mani swap on y7 turbo obd2-1 swap questions
- D16y7 Engine up grades?
- 1999 Honda Civic SIR - Question
- engine trouble
- Brand new Ebay header for 50 bucks??
- Any Ideas?
- Exhuast Recommendations
- Exhaust Whine
- Header for 97
- Quick Camshaft Question
- Have to do hg swap
- Questions about eBay products...
- Cai tb port -99 ex
- The dreaded D16Y7 exhaust crack -___-
- Best exhaust?
- My take on intakes SRI CAI vs Stock
- which brand is better?
- opinions?
- cold ai intake
- 99 civic lx
- Skunk2 Header
- horsepower/torque
- Catback exhaust OBDII back pressure??
- Adding HP
- CatBack exhaust Systems
