- SWC connection - Atoto F7 WE in 2006 honda civic EX sedan [solved]
- Swap a 2014 Radio into a 2012
- 08 civic Exl Stere upgrade
- Radio Swap 2018 to 2014 Civic w nav?
- Head unit, sub and Amp for 2015 honda civic sedan LX problems
- Aftermarket Radio in Civic 8th Gen hatch (Dash Display)
- USA Spec BT45-HON3 Bluetooth Question [solved]
- Nav start up
- Radio to Amp Issue.
- Retrofit headunit
- 2009 (58 Plate) Honda Civic EX I-VTEC
- Aux to USB mod
- head unit for 2014 coupe lx
- Looking to upgrade my sound system
- Sirius SXV200 install help
- Custom tweeter pods.
- 2008 civic Aux options
- What speaker size does the 8th gen European hatchback have?
- 08 Premium Sound Amp's
- Car Stereo Bluetooth 2 DIN to Honda Civic 9 EX-L, Help
- VSS/ speed sensor
- Speakers, replacement, 2008 EX Cpe.
- Head unit illumination wire help
- New Horns on a 2014 Sedan
- Replace old radio from 2008 Civic Hatchback
- What is this
- Aftermarket Stereo Steering Wheel Controls
- Civic DX 2014 aftermarket radio installation
- Alternator upgrade
- Dash kit needed for aftermarket radio?
- Civic Si speakers same as non-Si?
- Plug and play headlights??
- Magical headlight upgrade!!!
- Headlight kit recommendation
- 2007 civic hybrid Parking lights stay on constantly
- options for in-dash audio and nav using iPhone lightning cable
- Dimmer wire and Steering Wheel Audio Controls - 2012 Civic EX Sedan w/Navigation
- No power at all again
- Battery upgrade for 2012 Civic
- Wiring 8th gen horn plug to a Nrg short hub
- Brake fuse and cruise control fuses?
- How do I fix this. What is it?
- Head Unit / Handbrake cable query
- Wiring Issue with Pioneer W4400NEX...Help Please
- Honda Civic 2013 charging battery issue without lights
- Headlight LED Bulbs Recommendation
- NAV Software Sources
- 2015 civic se HDMI splicing. Want to use factory hdmi port
- VSA Check system message on civic 2007 Type s
- Command Start problems
- Speaker Replacement Question
- 2014 Civic Coupe LX - A pillar - wires came unplugged, what was it?
- Scosche HA13B product warning & solution
- Wireless camera to wired possible?
- No Audio on Android SWM8802 Audio Head
- Android car radio install?
- Tire Blow out - Ripped apart wheel well harness
- 2012 Civic Si Hazad Fuse blowing
- Battery drain
- How to upgrade the original car radio?
- Wiring questions for Backup Camera
- Radio Question
- Can Honda permanently bypass the Immobilizer System?
- 2 questions
- Weird electrical roaming issue
- Front Speaker Failure
- 2013 Honda Civic Shakes Violently When Braking With Traction Control Is On
- Immobilizer Issues
- Radio issue
- Dash warning lights.
- 2015 Civic Deep cycle battery Installation
- intermittent start problems.
- airbag light 2009 Civic LX Coupe
- Brake lights not working 3rd one is
- Need help wiring my ac compressor
- 2013 Honda Civic LX Sub cutting out at high volumes
- Right Rear Speed Sensor
- Honda CIVIC 2007 OBD Communication Issue. Can't read codes
- All turn signals and hazard lights stopped working after connecting trailer
- Changed aftermarket radio. No sound anymore
- Low/High Beams not working.
- 2007 Civic Si 4dr Radio Problems
- honda civic hybrid 2006 not starting - green key flashing
- battery discharge problem?
- changed radiator now radio keeps changing stations
- Cellular Signal Lost Pandora - via USB
- Anyone DIY remote start on Gen X
- 2014 LX Remote key (not fob) has stopped unlocking doors
- Where to get genuine 12 lighter socket?
- Can I reach the rear window heater wire ?
- Door switch malfunctioning
- car audio
- How Many Clocks Do I Need?
- Need Shop Manual to Wire Civic 2012
- Aftermarket Radio turns on speakers dont
- Problems with Handsfree Function
- Multiple Warnings
- Bluetooth and Pandora problem
- Android Car GPS Navi for Honda Civic 2006-2011 from China
- ELM327 compatibility
- 2007 Navi Package Aux Issues
- Aftermarket backup camera installation - 2014 LX sedan
- 2015 LX power window
- Tried USB Aux Cable, Car Now Dead
- 2015 EX / iPhone 7 Plus BT - receive text but it does not show sender's number
- srs light on
- Programming Keyless FOB
- Stereo/Radio Issue
- Is the 2009 Civic ODB2 port "live" when the car is off?
- 3rd brake light
- Won't start.
- Dash dimmer wire.
- USB port no longer works
- Switched hot wire
- Wiring Question
- 2009 civic radiator cooling fans running battery dead
- 2006 civic ex sunroof motor
- Fault On the EPS Control Module Circuit
- New doors, power windows not working
- JBL Speakers upgrade for Civic...?
- 2012 civic LX 1.8. ways to add coolant temp sensor for aftermarket guage
- 2013 Civic touring Navi / software update
- How to stop autoplay of music when iPhone connects to HFL?
- 2012 Honda Civic - OEM Upgrade Options for Car Radio (Navigation)?
- 2012 Honda Civic - OEM Upgrade Options for Car Radio?
- Help with Factory Amp/ Stereo
- heater fan'radiator fan
- Stupid question maybe, about interior lights
- Radio/Clock Backlight not working properly
- 2008 Hybrid, electric windows
- 2010 civic LX backup camera install
- 2008 Civic Electrical Problem
- Headlights/car audio not wired correctly
- Bluetooth Module Location
- Bluetooth not displaying
- Setup the radio
- Installed wrong battery
- Two general questions
- LED Running Lights
- Advice needed about adding speaker amp in a Hybrid
- 2006 OEM Radio Gone Bad
- Problem with fuel gauge indicator - intermittent
- Bluetooth and Media screen display
- New head unit settings
- USB Connection
- Display Wallpaper
- Audio installation for 2015 civic (help required)
- Subwoofer
- 2012 Nav replacement
- 2013 Civic EX 1.8L Alternator Help
- 07 civic si Stock Radio cuts off and on when using the defrost or A/C
- Want to add new switch to dash of 2009 Civix EX Sedan
- Front Right Speaker Shuts off When Turning on The Car
- Intermittent interior lighting issues
- CIVIC SE 2015 - How do i connect phone screen to car screen?
- 2014 civic ex sedan Sub/amp install?
- 2012 Honda Civic Secret Menu for DSP Off?
- New Head Unit for 2010 Civic
- Aftermarket system
- Gauge cluster flickers and turns off!
- 08 coupe speaker upgrades worth it?
- 2007 Civic - flat battery every 24 hours - MICU/fuse fox replacement? help
- '07 Civic door locking issues
- How to use ipod itself while plugged in usb mode? 2012 Civic EX
- Any benefit to speaker upgrade?
- OnStar add-on
- 2010 Civic EX Head Unit
- Album art 9th gen.
- wire colors
- GPS radio suggestions
- 2009 Civic sounds distorted with bass up.
- 2007 Honda Civic Hybrid, IMA has gone bad, and regular battery keeps dying
- Intermittent cranking
- Left mirror can't fold - civic 08.
- 8th generation speedometer problem
- mbloor
- Key chip removal
- Does the 08 ex's premium sound system have subsonic filters?
- Alternator/Fusable Link
- Bummed Out
- sat nav in which model
- how to connect central locking to alarm civic 1999
- Electrical problems wanting to shut car off
- 2015 Civic EX: How to change the high dash wallpaper
- Help! Honda Civic sedan 2012
- MICU replacement question
- 1amp drain at #23 UH fuse, overnight battery drain
- Enter Code Message
- audio
- ANC mic locations
- voltage issues
- Power windows have no lights 2012 Civic
- New ignition
- Power socket blown fuse
- Locate ignition switch hardness
- Big 3 Upgrade 2014 Civic
- Honda Civic Tourer EX Plus SATNAV
- HELP - Broken Nav Screen!!!
- Installing a different HU
- civic 14 usb problem
- 09 civic lx navigation xm upgrade
- Identiying Ignition Sense Connector (Under-dash fuse/relay box end)
- 2014 civic ex cd player
- 2007 civic Ex Navigation System
- Stereo sound question
- Upgrade headunit, keep stock amp
- Help
- blue remote wire
- Radio quality
- Audio upgrade question
- 5 pin underdash lighting switch install
- LED reverse bulb for 2014?
- Backup Camera 2013 Civic EX Sedan
- 2006 Honda Civic will not keep running
- 2008 tdi 2.2 noisey heater fan
- shielding an RJ11 cable from side pillar airbag
- Illumination wires?
- GPS antenna modification
- 2008 SI with Navigation need Bluetooth
- 2010 civic headlight relay location?
- Door Actuator
- Anyone have factory remote start?
- Is turning AC on and off harmful for the car?
- Again ILLUMINATION and DIMMER (Civic 4D 8th Gen and Alpine)
- 2010 Honda Civic HU Suggestion?
- Key gets very hot in 2008 Civic ignition
- 2011 Civic-intermittent radio/CD Static
- Need help with 2007 Civic LX radio light
- 06 Civic Intermittent Power Door Lock Actuator Issues
- Compressor, Engine or Spark plugs ?, What is causing this....?
- When fan's air flow direction is towards windshield, is AC running?
- 2013 EX-L w/ NAVI - Audio System Build
- Need help with speakers/installation
- 2006 Honda Civic 2.2 icdti stuck in limp mode
- 2012 IMBD lx, HF update, interesting
- Radio screen cracked
- 2012 Civic ex tach wire
- battery wont stay charged light is on
- 2012 Honda Civic LX NAVIGATION
- 08 Civic Ex radio
- Need help choosing subs!
- 9th Gen - Car Battery
- MP3 Player+In Car Cigarette socket
- Options for XM ready hookup to Sirius?
- Anyone have experience with one of these?
- Random Play Mode
- PO 128 code need help
- How to read the speed?
- Radio antenna connection locations
- No Power to Factory Radio Sometimes -2006 Civic LX
