Speeding Ticket Help!
I recently got a speeding ticket (53 in a 35) by a local cop. He got me right were the speed drops from 45 to 35. I don't know how he clocked me. Local cops can't use radar and there were no lines on the road. I know cops can use monuments to clock your speed, but it was night. The only thing across from her were to speed limit signs, one of which is cover by brush. How far do the monuments need to be apart? Any info would be appreciated?
The signs that were covered in brush were for traffic traveling in the other direction. The cop probable used them as monuments to calculate me speed, not sure though. I was hoping someone knew how far the monuments had to be apart in order to get an effective speed calculation.
Originally posted by kyle4583
i find it hard to believe local police agencies dont use radar. just seems weird they would not be interested in traffic enforcement.....
Injen
I think there's a law that doesn't allow them to use radar. Is pacing were they follow you? This cop followed me for less than a mile. I think he was using a VASCAR system.
pa local cops cant use radar, only the state troopers can use radar, its a state law. its quite hard to prove ur speeding in pa locally unless u are really speeding obviously or like they are tailing you
If you know how long it the officer was timing you, then you could figure out how far apart the monuments need to be. So far you know you were doing 53mph (which is the same as 77.73 feet per second), or so the officer said. Just take that number and multiply it by how long the officer timed you. That's how far apart the signs have to be. Or, an easier thing for you to do, measure the distance between the signs, let's just assume 155.46 feet. Then ask the officer how long you were timed. 155.46 feet / 77.73 ft per second = 2 sec. So, you would've had to have been timed for no longer than 2 sec. If you were timed for more than 2 seconds, then the officer's claimed speed is wrong.
So like I said, measure the distance between the two signs. Then take that number and divide it by your claimed speed, 77.73 feet per second. Then you'll get an answer corresponding to the time that you were clocked for. If his response is equal to or less than that time, then it would match the speed. But if the time is over the answer, then the speed is inaccurate.
Just remember distance = rate x time, or time = distance / rate
Yeah it is. That's the same formula with two of the variables moved around. Yours will give you the speed if you know the distance and the time. Mine simply solves for time, since he knows the speed and can measure the distance.
psykh00 is right. I teach 9th grade physical science. I know all about calculation speed using the distance/time formula. You can also manipulate the formula like psyh00 did to solve for distance or time. You get an A+ psykh00!
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
Bricoleur
Sep 9, 2015 12:23 PM
Touge
Sep 1, 2015 11:25 PM
