looking for transmission
Rep Power: 0 looking for transmission
Im looking for a transmission for a 2007 Honda civic Si 4dr. transmission and clutch completely shot any recommendations On where to find them?
Re: looking for transmission
Why replace a transmission if it just needs a clutch job?
Clutch you buy new. Never used.
Rep Power: 0 Re: looking for transmission
The transmission was replaced before and they put the wrong transmission in they put a stock civic tranny in so it ate up all the gears. Its and Si so it needs and Si transmission
Maybe it was actually correct but someone forgot to fill it with lube or it leaked out, that would certainly ruin a trans.
Does the speedometer climb if you try to drive it? Does it make noises? Maybe it broke an axle or something (rust/salt belt problems).
Same thing happens if one breaks an axle, or an axle pops out of the trans......see where I'm going with this yet?
Have you actually inspected to see why it won't move, or did you just guess it needs a transmission and clutch?
Good point thanks ill have to have my brother jack it up and look at it hes a mechanic so he should be able to tell me is the axel cheaper and easier to fix
