DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
Old 12-31-2007
  #211
NastyNunez's Avatar
NastyNunez is an unknown quantity at this point
Re: DIY: K20/K24 into 2001+ Civic **Updated 11/24/2007**
lmao x you right. I just read the "parts you dont need, but hasport said you do need" a little to fast It says Shifter assembly. lol
Old 01-03-2008
  #212
Yaj00003's Avatar
Yaj00003 is an unknown quantity at this point
Do you really need a brake booster line I thought our civic have it already...and what part of the throttle cable you need...thanks...trying to get all the info I need to do the swap...
Old 01-03-2008
  #213
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
not be mean.. and i really mean not to be mean or anything..
BUT....
those questions u just asked are answered in the DIY... lterally.. the first 20 seconds of reading the DIY will answer your questions
Old 01-05-2008
  #214
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
As far as the front engine mount goes, I did buy an OEM type S front engine mount and install it, it fits perfectly. As far as do you need it I am not sure, but for $70 why not. I mean there is a place for it for a reason even the low hp D17 has 4 engine mounts. IMO the front engine mount should be installed, it just adds for that much more stability and less stress on the drive train, suspension, and many more parts of the car.
Old 01-06-2008
  #215
if you go with a k24 then now that front mount is useless.. u have to take it out.. it binds together and makes the motor hit the frame and mount together... so now u have a pointless mount
reason you dont need the front mount is because the hasport mounts are solid rubber filled and motor has close to zero shift with there mount.
now if we were using stock mounts where they are not soild filled then yes using the front mount is required. thats why hasport only included 3 mounts with the kit....
yes there is 4 mounts and a place for everything.. but that only exists when its stock and direct from the factory... aftermarket upgrades have a difference otherwise
Old 01-06-2008
  #216
EMK20a2's Avatar
I was not aware that it would not fit with the K24, good to know. Atleast with my setup, as much stress as constant autox/track days all with R-comps put on everything, my engine side bushings already need replaced on my hasport mounts. I am even going to throw urethane inserts in my front mount to stiffen things up even more. Maybe it is all in vain, I guess we will see if that engine side mount holds up this year.
Old 01-10-2008
  #217
Yaj00003's Avatar
Guys well I was wondering what is the best brand radiator for our car...
Do you guys this this radiator is good...I think it cheap....but I was thinking about Koyo radiator...what would you guys perfer or just the stock...
http://www.autozconcept.com/product_...oducts_id=4254
Old 01-10-2008
  #218
TURTLEonK
Nameless's Avatar
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ Never heard of that company in that URL but Koyo is good.
It all depends what you are doing with your car... Do you really need an aluminum radiator?
Old 01-10-2008
  #219
its up to you.. i went from stock rsx.. to a cheap aftermarket.. to ended up going koyo... so if you want to skip all that then go straight to koyo.. if you go tthe money for it
Old 01-24-2008
  #220
Yaj00003's Avatar
Sup guys about the power steering, well the K20a3 use EPS (electrical power steering)...I was trying to find out...how do you get power steering....
Old 04-21-2008
  #221
Re: DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
Just updated the write-up again...
added/modified the following
-rbc fitment issue
-explanation of k20 or k24 mounts
-more details on the o2 sensor wiring
-air conditioning installation
-shifter box comaprison
-and a little preface message
Old 04-23-2008
  #222
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
very nice X. I've been looking for that shifter comparison for a while. I noticed that you said the revo is .75" shorter than the rsx shifters. Isn't there two different revo shifters. I have the revo for an 01 civic and it is .75" shorter than the OEM unit. Since the civic shifter is already shorter than the rsx shifter, wouldn't that make the revo for the civic 1.5" shorter than the rsx shifter?
Old 04-23-2008
  #223
u sure??.. cause my revo and my stock oem were same height when i pulled it out and had it side by side
Old 04-26-2008
  #224
Wicked Pissah Admin
Havok2k1's Avatar
Old 05-19-2008
  #225
paradoxblue's Avatar
so whats your take on this new franken motor i am hearing a bunch about as of late?
Old 06-06-2008
  #226
513steve's Avatar
513steve will become famous soon enough
Great writeup, I am hitting the junkyard tomorrow ot start buying part for the swap.
Old 07-21-2008
  #227
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
bump!
Old 08-26-2008
  #228
EMK20a2's Avatar
Just giving some of you guys who are debating a swap a heads up. I have a K20 EM2 for sale for a great price https://www.civicforums.com/forums/1...-new-pics.html
Do not post any replies in this thread, either PM me or post them in the linked thread.
Old 11-15-2008
  #229
Deepa's Avatar
Deepa is an unknown quantity at this point
I've read this thread and a few others but I've still got a question.
Basically I have an ES1, and a chance to buy an RSX with a lot of body damage. Now if I wanted to swap both front and rear subframes complete w/all suspension (incl 5 lug swap/brakes, axles) could it be done?
I did search, and I know I can use the front subframe, which means the front suspension (along with the K20) will swap in, but the only info on the rear is that RSX lower control arms won't work with the Civic subframe, but if the DC5 rear subframe bolts in the control arms will too. I'd be grabbing as much of the interior as possible as well (seats, console, dash, gauges, etc.)
Anyone know if the DC5 rear subframe will bolt into an ES1 chassis?
Old 11-18-2008
  #230
Deepa's Avatar
I'll paypal $20 to whoever can answer this one, if it matters, the donor is an 05 RSX Type S and the recipient is a 2002 LX Sedan.
Old 11-24-2008
  #231
Deepa's Avatar
Figured it out, will post pics in a few weeks
Old 11-25-2008
  #232
EMK20a2's Avatar
Not trying to jack the thread, but I have a EM2/Kswap header exhuast setup that has been proffessionally modified to fit, just bolt it on and go. This is a great part for you Kswappers that will save some time and $:
https://www.civicforums.com/forums/1...setup-em2.html
Old 02-28-2009
  #233
sbaksh's Avatar
sbaksh is an unknown quantity at this point
Originally Posted by xproductionz
As i go along let me know if i missed anything so i can add it in
Also if anyone has some pics i can add then that would help too
**note- this is for anyone.. im not on here everyday. So if you need help or something im on my site everyday XproductionZ.com :: Ver. 3.0 on the forums if you need it.
UPDATE 1/7/2007 (Slightly Updated)
**also note that the same thing applies to people who do the k24 swap. Just remember that if you use a k24 that the passenger side mount is different from the k20 passenger mount. If you already have a k20 in your car and wish to use a k24. Hasport and i think Hybrid can supply only the k24 passenger mount so that way it sits the motor lower so it can fit in our cars
**If you need a relay to do the the wire harness for the O2 sensor i can get those for you
Mods done to the car in the swap
Hondata
Type S manifold and Base TB.. (took out the dual intake runners)
Megan Race headers
Megan Race Downpipe
Custom 2.5 Piping
Megan Race Exhaust
Custom 3in Intake
and the Dyno
UPDATE 4/29/07 - Read Below
An RBC manifold on a K20 and/or K24 using Hasport mounts will fit the 01-05 chassis. Just did the swap yesterday. Took out the K20a and put in a K24.
However you will need to trim away at the upper radiator support area to make it fit. You have to trim about 3/4 an inch away just to make it clear.
Minor UPDATE 11/24/07:
For those of you who use a relay other than the type listed in the DIY. There are aftermarket relays but they all use a universal number to identify the pins..
Some of you might remember this image of the relay pins..
Heres is what each number stands for:
1 - 30
2 - 87
3 - 86
4 - 87a
5 - 85\
Just updated the write-up again... 4/20/08
-rbc fitment issue
X, When Installing a K20, won't it be easier to remove the whole front radiator support ?
https://passwordjdm.com/images/Produ...rt%20Large.jpg
I've noticed you trimed the radiator to fit the manifold, now is there any shorter one that you can use without cutting the radiator, or a aftermarket rad that is thiner ?.
You have one of the best DIY on the net, too bad you don't have a hi-def how-to DVD on k20 swap. I would buy it for sure.
Old 03-07-2009
  #234
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
No it is not necessary to remove the radiator support.
He trimmed the radiator support area to fit an RBC (06&up SI/euro accord)manifold. The K20a2/Z1 comes with the PRB (rsx type s/civic si) manifold which will fit without trimming. The PRC (integra type R) will also fit without trimming
Old 03-07-2009
  #235
Mr_Plenty's Avatar
His diy is great read it over and over and you'll get it
Old 10-17-2009
  #236
BigRedEXcoupe's Avatar
BigRedEXcoupe is an unknown quantity at this point
Easier said than done. His site is down :/
Old 10-26-2009
  #237
CaliDanSD's Avatar
CaliDanSD has a spectacular aura aboutCaliDanSD has a spectacular aura about
did anyone save this write up, because his site is down.
thanks.
Old 10-27-2009
  #238
streetthrowback's Avatar
streetthrowback should not be trusted
yup i did
Old 10-29-2009
  #239
oh snap i thought i did
Old 11-08-2009
  #240
its back up.. i was moving into a new home
Quick Reply: DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
