Intercooler Piping!!!!!
Old May 25, 2004
HyaBoosta's Avatar
Exclamation Intercooler Piping!!!!!
OK im going custom turbo i've got everything i need except for the intercooler. I know it's been covered alot before and i searched, but im looking for someone out there who has a opposite end intercooler with pics. i know there are pics out there but not what i need. i need some pics with the bumper off, or right up on the ac side. I mean some up close money shots anyone have those?
Holla!
Old May 25, 2004
civic01vtec's Avatar
PM opto_isolator and Boosted2k2 and i'm sure there are a couple others that have them too.
Old May 25, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
i got one
Old May 25, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
http://www.team-upgrade.com/members/dan/dan06.jpg
sorry its all i got!!!!!
Old May 25, 2004
HyaBoosta's Avatar
i notice the piping seems to be bent down on all the pics. does anyone know where they lead? are they going uner the core? on top?
Old May 26, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
probably under the core and routed the same way the sf intercooler is routed.. except its just not as ugly as the sf intercooler is..
Old May 26, 2004
HyaBoosta's Avatar
can't your piping bend then if you hit a bump or on speed bumps?
Old May 27, 2004
HTOWNBOY's Avatar
my piping is routed between the core support and sub frame with 2" pipe. it was very tight but we made it fit.
Old May 27, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Old May 27, 2004
Im going down and under the core and the bend is messin up my spool time. u can go in the drivers side and next to the oil pan and up next to the intake manifold. thats next!!
Old May 27, 2004
HyaBoosta's Avatar
so for spool time is it better to get an intercooler that has inlet and outlet on the same end like the sf? because now johnnyracecar.com is selling an intercooler that looks like the sf but at a much better price.
Old May 27, 2004
im not saying either is better. but the straighter the pipe the better the flow and less turbo lag. if u have an lx or lower you'll have no problem (no abs in the way). if not ur screwed. lol
Old May 28, 2004
HyaBoosta's Avatar
the only problem with the johnny race car same end intercooler is that it's 12" high. is that way too big to fit behind the bumper??
Old May 28, 2004
dezod's Avatar
7thgen Power Maker
I think your a little confused or mistyped. Lag is a function of proper turbo size and motor displacement. It has nothing to do with the I/C. The I/C creates DRAG which steals a fraction of the total PSI being pushed out because of improper sizing of the I/C to the vehicle, turbo and displacement. True the straighter the pipe the better, bends can be made, but think of your airflow as a massive crowd of 1,000,000 people trying to run to one place. The mobb doesn't flow through sharp turns, but slowing narrowing smooth curves help a lot.
Edit: The I/C helps turbo efficiency due to temperature drops. On average a properly sized I/C should drop temps 40-60%.
Old Sep 6, 2005
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
so like the million-molecule march...err..run...sprint???
lol
Old Sep 6, 2005
eye_see_you's Avatar
let the devil out
Old Sep 6, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Good install for the TSI kit!
But why pics are placed in this forum?
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
