Light weight flywheel?
Rep Power: 0 Light weight flywheel?
Has anyone Experienced any negative results or problems using a lightened flywheel and stage one clutch with heavy duty pressure plate on stock motor 1.7L
Received 1,440 Likes
Rep Power: 338 Re: Light weight flywheel?
there is no reason to use stage 1 without a turbo
Agree with sdaidoji on the clutch, stock is fine for a stock engine.
Extra stiff clutch can cause the crank to eat its thrust bearing.
Lighter flywheel: Less stable idle due to less rotational mass, and tendency to set false misfires?
\IDK, no personal experience on this.
FWIW I know an engine builder who chose to use extra heavy flywheel on an engine-----then his air cooled VW Bug would pull the front wheels in the air.
Light flywheel will make you lose torque. No power gains, just rev happier.
Like ezone mentioned, heavier makes torque delivery consistent
I run one, the engine will come up to RPM's easier, help's take of a good bit. I use a stock clutch, have had no issues with it, have a good 2500 laps on it
StaticFire450
02-04-2011 05:18 PM
MZ
20
01-15-2003 03:41 PM
