pistons
pistons
since i intend to fix my oil burning furnace of 1 qt every 1000 miles on my honda this summer.
i came up with an idea to do this on my pistons..
this should help in not getting stuck oil rings ..
wonder what SDDjoi and ezone think.. it should remedy the issue also..
Re: pistons
There are K engines with those holes, I know my 07 Fit engine has the holes.
I know some other engines don't have the holes..........
The holes won't prevent the rings from getting stuck.
Re: pistons
the idea is you have more passage way for the oil to drain back, so it gets less cooked up carbon build up...
i am going to test it on mine, but i doubth i will keep it another 300,000k miles to fiind it if it worked) hahahahahah.. so the question is why do i even do it
i researched it been done on toyota's and saturns as to alleviate the problem
Re: pistons
Oil quality plays a big part in coking in the ring grooves.
A piston gets hot. Extremely hot.
Newer engine designs have pushed the ring locations upward ever closer to the combustion area, so now the ring areas get hotter than they used to on older designs......
High quality oil tends to (for lack of better term right now) 'carbon up' less or later than lower quality oil because it withstands higher temperatures before breakdown
Re: pistons
i used mobil one synthetic on mine every 3k since 2005.. that religiosly very rare these days.. maybe that's why i didnt cook the oil rings till 270,000 miles .. hmmm
Dr Krieger of Modification
Re: pistons
...That won't help your oil consumption problem.
That would help if it consumed due to insufficient flow from the factory; but that is not a known issue with d17 engines.
Your vehicle is burning because oil is entering the combustion chamber some how.
-worn out piston rings/oil control rings
-worn valve seals
-worn cylinder walls
-all of the above
-or like in my case over pressurization due to stock pcv system and aftermarket parts.
-worn valve seals
-all of the above
Re: pistons
-worn valve seals
-all of the above
-worn valve seals
-all of the above
Rep Power: 97 Re: pistons
I have a few questions. Not to be an ***, but for my own personal knowledge.
1) How do you know it's stuck rings?
2) If the rings were sticking wouldn't the cylinder walls be scored from the rings
due to the lack of lubrication?
FYI my civic had 265,000 miles on original parts (minus timing belts) and i was not burning any oil...until I slapped a turbo on it
Of course all engines are different.
If what you say is true of all the tests, i would personally look again at the valve seats....
Re: pistons
Actually having pulled mine apart, no the cylinder walls aren’t scorched, it’s the exact opposite.
Seems once the oil starts cooking in the oil control rings, the three separate rings become one solid mass and they lose the ability to expand out and wipe the oil off the walls.
So the oil rings effectively become flush with the piston side and oil is no longer getting wiped away.
Fully agree with what has been said, I would possibly even speculate that the extra stuff in high mileage oil might even cause more clogging..
As too making the holes bigger, I don’t know. As you said with synthetic oil and timely oil changes you went past 200,000 wherein my donor engine which in 75k miles has documented over 9 oil changes but at a discount garage already had pretty crusted up oil ring.
Re: pistons
i will let ezone answer this, piston compression is good.. its the oil ring that get carbon build up or cooking.
newer modern engines they put them all rings closer to combustion.. that means heat more.. now as i seen the oil in the ring groove doesnt drain fast enough and it cooks up as a carbon build up over time.. now there is mod i can drill extra holes have oil drain faster and reduce this for next time..
i tested compression 210, wet dry u named, i tested cylinder leakage. all good. i pressurized the cylinder with air to see where it comes out of.
how do i know its not my valves, i did a headgasket before, replaced the valve stem seals, replaced my bent valves .. plus culinder leakage test will show ..
trust me i know its the oil rings on mine. as for the cylinder wall, when the head was off i checked them they werent scorched.. the only thing i regret EZONE told me to replace the rings due to this known issue, but i hadnt had oil burning before, .. so i assumed they wont cook up.. eventually they did..
should have listen then, but its ok i can do the job twice,.. labor is free plus i can modify the pistons with few extra holes so il can drain faster.
Received 1,440 Likes
Rep Power: 338 Re: pistons
ezone have more experience with this, so i will let he do the talking
Re: pistons
Experience and sense leads to the hunch, but usually there is little or no way to prove it until you take it apart and see with your own eyes.
Kinda hard to diag by blue smoke while a working cat hides most of the smoke.
Oil is passing through with too little control as it is right now. How you figure lack of lube?
This.
I never really bothered to take pics of pistons from other engines I do, but have this one for some reason
My Fit pistons @200,000 miles, had been soaking in cleaner.... link to full size pic if you want to try to see the oil rings
https://i.imgur.com/TmgrCUQ.jpg
Done in-car
FYI ring gaps can move around and if they happen to align just wrong that can allow excessive oil to pass through the gaps too.
Done in-car
Re: pistons
i get 1 qt every 1000 miles depending on driving on average.. hasnt gone worse, at 320,000 miles.. sometimes i wonder how long i can drive it like this.. will it get worse..
being a fixer, everything working on my car as it came of factory, i like to fix it..
lots of work, **** my reverse just lost itselft at 320,000 also... i hate to fix it and someone rear ends me , and get peanuts for it)
sikciv00
02-08-2011 12:38 AM
ModNewbieHELPME
25
01-24-2002 07:41 PM
