Engine building Post information/questions about Engine Building here!
Ktuner and the D17
Old 08-28-2018
  #211
Received 1,144 Likes on 799 Posts
Re: Ktuner and the D17
jeebus. Am I reading their website correctly and that goes on an 8" rim?
http://www.mandhtires.com/9.0-22.0-13
edit: now you needs stickers like me. lol
Old 08-29-2018
  #212
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
8" Rim is correct.
I'm ordering 13"x8" bassett rims with a 3" backspace today.
Old 09-02-2018
  #213
piano55man's Avatar
Let there be TRACTION!!!!!
Old 09-02-2018
  #214
good. lord. that is all.
Old 09-07-2018
  #215
Nelrodjr's Avatar
Nelrodjr is an unknown quantity at this point
Installed kpro, now noticing battery light is always on. Did you come across this?
Old 09-07-2018
  #216
piano55man's Avatar
Nope, but send me a PM asap.
Old 09-21-2018
  #217
piano55man's Avatar
Made a short throw shifter adapter plate last night...
https://www.civicforums.com/forums/7...r-adaptor.html
Old 10-12-2018
  #218
piano55man's Avatar
Just got real when i pulled the tranny apart...
Going to re-seal the tranny and throw in a lsd block.
Old 10-15-2018
  #219
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
tranny is holding up?
Old 10-15-2018
  #220
piano55man's Avatar
Installing a LSD block.
While it's all apart, going to put new seals in it.
Old 10-15-2018
  #221
5.0Thunder's Avatar
but none of the gears are trashed and the case isn't split so that's good. hahah
Old 10-15-2018
  #222
piano55man's Avatar
Their good for now....When i unleash all the horses with my slicks, i may be utilizing my spare tranny...lol
Old 10-25-2018
  #223
piano55man's Avatar
New seals are in, waiting on input shaft bearing to come in next week.
LSD block should be in by early next week as well.
Old 11-05-2018
  #224
piano55man's Avatar
LSD block for a d16 does not fit a d17 tranny....
I will be putting my lathe skills to the test this week cutting the differential gears down so everything will fit.
Man, nothing is ever easy with this 7gen...lol
Old 11-07-2018
  #225
Erf_Em2's Avatar
Erf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of light
Lookin good with the wheels setup.
It will be interesting to see if the LSD works with the machining you are doing with the differential gears.
Old 11-09-2018
  #226
piano55man's Avatar
After cutting the inner large gears lip down the lsd block fits and is installed!
Old 01-30-2019
  #227
piano55man's Avatar
Winter mods almost completed....
New D series 70mm Throttle body coming in tomorrow.
Updated Ktuner ecu module coming in this weekend.
Upping the fuel pressure so i can push the injectors a bit harder.
Old 01-30-2019
  #228
Received 1,440 Likes on 1,196 Posts
Oh, yeah, you might have gotten the PM, we are reviewing structures in the forums, so some of your threads are being moved to other sections. Let us know if you have issues with that.
your build involves several different areas in engine work, do you prefer it to be at the root of engine performance?
Old 01-31-2019
  #229
piano55man's Avatar
That's fine by me.
The build is a turbo build but with an experimental ktuner ecu setup....which btw is working great!
Old 01-31-2019
  #230
Prelude Owner
GolNat's Avatar
Cool stuff going on here!!! Great job with everything and awesome 1/4 mile time!!
Old 01-31-2019
  #231
piano55man's Avatar
Thanks!
Old 02-11-2019
  #232
piano55man's Avatar
I feel like my D17 is becoming a D16 with each and every mod.
So last night i cut off the throttle body flange of my D16y8 intake manifold and started porting the opening from the stock opening to 70mm.
I cut the flange off because it didn't look like there was enough material for a 70mm hole.
I made a replacement aluminum flange that will accept a 70mm D series TB...now i have to rewire the TB sensor to accept the old version.
I have a buddy who is going to tig weld everything back up. I'll post up pictures tomorrow.
Old 02-12-2019
  #233
piano55man's Avatar
I cut that little tab off
Hand placement is about as close as it's gonna get. Time for the tig!
Old 02-14-2019
  #234
piano55man's Avatar
Not enough space to tig the whole outside so we did the whole inside and about 1/2 of the outside.
Used jb weld for the outside and as it was drying, i sprinkled grindings on the jb weld. My theory is it will help strengthen the bond but also makes it look nicer...
Old 02-14-2019
  #235
Dr Krieger of Modification
mac25's Avatar
Looking good man 😁.
ps: Don't worry about the cut lsd block, I cut mine with an angle grinder 2 years ago.
Old 02-15-2019
  #236
piano55man's Avatar
Thanks!
Old 02-15-2019
  #237
looking good man! btw, my 2018 is now k-tuned pushing 21psi boost
Old 02-15-2019
  #238
piano55man's Avatar
way cool!!!
The stock fuel pump and injectors handling that much boost or did you swap them out?
Old 02-15-2019
  #239
Stock everything can handle it and KTuner included basemaps to adjust the wastegate for extra boost and fuel maps to accommodate.
Old 02-15-2019
  #240
sidenote: the tunerview app for smartphones is awesome (only $5) , assuming the KTuner board you have installed has bluetooth connectivity.
Quick Reply: Ktuner and the D17
