D17a1 m/t vs d17a2?
Rep Power: 0 D17a1 m/t vs d17a2?
Will a D17A1 manual transmission bolt right up to a D17A2?
The tranny on myD17A2 **** the bed so i'm searching Craigslist locally for a new one and wondered if the D17A1 tranny would fit?
Thanks,
Dave
Thanks,
Dave
Rep Power: 188 Re: D17a1 m/t vs d17a2?
It will bolt up no problem. I just did the same swap this afternoon. Make sure to remove the clutch slave cylinder so you don't have to bleed the clutch
Alright guys need help my D17a1 is acting up real bad - looks like its gonna kick the can soon so I need to get a new engine only, looking to get a
D17a2 on that bad boy but I need to know everything i need to to get it done. Please help gonna take two weeks off from work to get it done so a quick response will be greatly appreciated.
1 Post
Rep Power: 328 Re: D17a1 m/t vs d17a2?
The extra few Hp isn't worth the cost. You will need d17a2 ecu,wiring harness, headers, o2 senopsors, and a few other things...
yeah the reason im set on it is because i havent been able to fine any decent d17a1 -- everywhere i look their selling the a2 -- anyone know where i can find a solid d17a1 replacement?
Complete Block
Complete Head
Intake Manifold
Exhaust Manifold
Throttle Body
Power Steering Pump
Injectors
Fuel Rail
Distributor
Alternator
Oil Pan
Sparkpluge
Valve Cover
VTEC Solenoid
D17A2 SOHC VTEC Engine only 01-05
Complete Head
Intake Manifold
Exhaust Manifold
Throttle Body
Power Steering Pump
Injectors
Fuel Rail
Distributor
Alternator
Oil Pan
Sparkpluge
Valve Cover
VTEC Solenoid
http://www.jdmtigerjapanese.com/hond...nly-01-05.html
here have a look I didnt see anything bout vtec e
thats for canada right?
now my ?? is with everything you see here what more would is needed
to make this work-- before I busted it had sum racing headers no cat
cold air intake and a magnaflow system
with a stage 2 clutch with the flywheel shortshifter
skunk2 lowering springs and new struts all around for comfort
cross drilled and slotted brakes on 17 " 205 45
looking to build circuit car I was on my way to that ex head and cams for sum more ummpphh but my engine got fried
also will my clutch flywheel headers intake magnaflow transfer over or nah
The D17A1=non VTEC
D17A2=VTEC-E (switching from 12 to 16 valve operation anywhere over 2,500 RPM) for fuel economy.
D17A(un-numbered)=VTEC with high performance cams in Pakistan models and some JDM/Asian units
Alright so anyone else have any info thats relevant to this or should i just try to find a d17a1 and keep as is --- also for some reason I read that a d15b was compatible with my d17a1 is this correct?? have a look here http://www.ebay.com/itm/JDM-Acura-1-...9065a5&vxp=mtr
The D15B head is compatible (as the heads are the same). Its the crank-shaft in the block that's different. A mini-me setup is going to be quite tricky.
I have the D15B block too, but I'm looking to increase displacement and raise the compression a bit. My D15B makes the same power as your D17A2, but obviously less torque due to the differences in crankshaft.
Yeah nah im looking to replace the hole engine and its a D17A1 not the D17A2 Im looking into replacing it either the D17A2 or the D15b but I dont want to be scambling for parts when the engine is out and im trying to get it running
Personally, I like the naturally quick response from my seventh gen D15B, but I like the torque of the D17A2? It would be great if Honda implemented the real VTEC in these units like the previous generations.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
BootyDo
06-21-2016 03:45 PM
tadr88
06-08-2015 12:28 AM
