Just Finished Installing my Turbo!
#31
Live for the Twisties
Rep Power: 260 Re: Just Finished Installing my Turbo!
The tuner definitely is not experienced with Hondas, but if your dads set on listening to him there's nothing you can do I guess. Go on any forum, see the guys truly pushing the limits of Hondas, they'll all recommend k-pro for a street car. That includes other tuners and shop owners.
As far as AC goes, the option exists within EMS and can be turned on when you go for the tune (more of the tuners time), but it's glitchy on Hondas. Evidence that I know what I'm talking about > https://www.civicforums.com/forums/7...aem-ems-c.html
#32
That Dude with the Questions
Rep Power: 174 Re: Just Finished Installing my Turbo!
On the topic of K-Pro. When you send in a donor ECU, is one ECU preferred over another? Like the ECU from an RSX-S over an SI? Or is it all the same at the end of the day?
#33
All the same I believe, I'd have to check to confirm, the following ecus can be used.
2002-2004 RSX Base 5 speed (PND -A0 ECU)
2002-2004 RSX Type S 6 speed (PRB-A0 - ECU)
2002-2004 CRV 5 speed (PPA-A0 ECU)
2002-2005 Japanese DC5 Integra Type R (PRC ECU)
2003-2005 Japanese Civic Type R (PRD ECU)
2002-2005 Civic Si (PNF ECU)
#35
Rep Power: 0 Re: Just Finished Installing my Turbo!
I have some RSX injectors, tuner said that they might be close to maxed out @ 7-8 PSI, what do you all think? What do you suggest? Getting some big ones like 400cc+?
#37
OEM RDX injectors, they have a factory turbo k23 and 410cc output, they should do the job until you push the boost higher.
https://www.civicforums.com/forums/7...cs-inside.html
#38
Any Update???? Did u go with the AEM??? Take my word for it... KPRO is the way to go... sooo easy to tune.. and there are TONS of d17 maps out there if u need something!!
#41
Tuned and road ready??? I might have missed it... Trying to get back on here and see whats crackin!!! What number he putting down?
#42
Rep Power: 0 Thread
NoobyKid
07-13-2015 07:53 AM
Bill in San Jos
07-10-2015 12:32 PM
fvckbg
07-07-2015 07:08 PM
robbie374
07-07-2015 02:56 AM
