Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
FYI: Engine Management Calibrations (D17 & K20/K24)
Old 04-29-2007
  #31
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: FYI: Engine Management Calibrations (D17 & K20/K24)
I also got a few tuned AEM EMS maps for the K motors but dont know if anyone is running it
Also got tuned maps for the S300 for the S-Manager and a few for the S200 and S100 but you need a rom burner to use it
Old 04-30-2007
  #32
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
do you have any more for the emanage blue d17 turbo
Old 05-01-2007
  #33
Buds302's Avatar
Buds302 will become famous soon enough
calibration for: Greddy Emanage (blue box)
software/version: support tool version 1.49 and Emanage main unit version 1.49
user: buds302
engine type: D17A2 2001-2003 Civic using Emanage
injector size: 310cc
all motor/turbo/SC: Turbo
boost level: 11psi
tuned by: 1320 motoring in hagerstown,md
dyno type: DynoJet
dyno temp: a cool 87 degrees
fuel type: 93 octane
mods:RSX Type S injectors, DEZOD V1 turbo kit, wideband, other than that an all stock motor
218hp/198tq
File Type: zip
10psiemanage.zip (577 Bytes, 126 views)
Old 10-01-2007
  #34
7thgen.nick's Avatar
7thgen.nick has a spectacular aura about7thgen.nick has a spectacular aura about
why do all these zips come in as corrupt files and cant open??
Old 10-01-2007
  #35
i went and tried downloading all of them... they all work for me
Old 10-01-2007
  #36
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
I'm having the same problem to they all say it is a corrupt file for me
Old 10-01-2007
  #37
even at work same problem.
If anyone can send me via email some maps to start with, heres what im going to this week:
01 vic d17a2
dezod T3/T04E
emanage blue
5.8psi
rsx injectors
walbro fuel pump
apexi boost controller
Old 10-01-2007
  #38
well everyone... u guys need something to UNZIP the file like winrar or winzip.. i tried it at work and now i know what u mean.. so i then installed winzip on my work computer and it worked fine after that
Old 10-02-2007
  #39
windows xp has an integrated decompressor in the windows shell... but aside from that, i took out the liberty and actually did download winzip and still had the same error, actually...
but yeah bleh... can you send me the files to my email?
Old 03-12-2015
  #40
poitrasr's Avatar
poitrasr is an unknown quantity at this point
There is my specs need a Good Map for Frankenstein K20/K24 in Civic Si 2008 coupe
engine info
head k20z3
head resurfaced .010 off
new oem honda headgasket
new oem honda valve seals
zerg thermal intake manifold gasket
hand port/polish
kelford 179-b2 cams
bc valve springs/steel retainers/keepers
stock valves 3 angle valve job
rbc manifold ported to 70mm tb
rdx injectors 410cc
rdx pigtail clips for injectors
k -tuned Coolant Temp Sensor Adaptor Fitting
k-tuned OEM Thermostat Housing Plug & Bracket
k24a2 block resurfaced/bored and honed to 87.5
stroke 99
micro polished crank
cp 12.5.1 x forged pistons 87.5
eagle rods
new honda rrc crank pulley
new honda rod bearings
new honda crank bearings
new honda thrust washers
new k20a2 oil pump
all new honda timing chains (cams/oil pump)
new honda tensioner
all new chain guides
all new honda seals/o rings
rsx type s knock sensor
rsx type s crank sensor
Aftermarket :
- Invidia Q300 Exhaust 2''3/4
- Invidia Race Headers 4-2-1
- No Catalytic
- Skunk2 CAI 3''1/2
- ZDX Throttle Body Big Bore 70mm
Need it for Flashpro please
Old 03-12-2015
  #41
Received 1,440 Likes on 1,196 Posts
hunh, sorry, all these were in 2007... and these were for the K20 for the 7th gen cars... you have a 8th gen car... you better off starting a thread on the 8/9th gen section...
hewey23
Suspension
09-04-2022 07:58 AM
F1wanabe
04-27-2015 11:06 PM
tylerginevan
04-27-2015 12:29 PM
plastikman
Bolt-on Engine Performance
12-13-2001 03:18 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: FYI: Engine Management Calibrations (D17 & K20/K24)
