Auto to Manual
#32
Super Member
Originally Posted by Civicman1988
keep us updated on ur progress man. whats teh deal with the ecu? do i need a manual one?
i need some1 with a stick civic to post of thier....
clutch pedal mounting points.. just snap a few pics behind the dash
clytch hydralic system ( the master cylinder mounting points, and the slave lines leading the trans )
other parts that might be changed?
do u need new mounts? i know u need a new subframe but will the other mounts line up?
do our car have a engine/trans stiffner? u know that little bracket that connects one part of the trans to the engione block? if we have do we need a manual one or can we use the auto one
Last edited by jamesandrew58; 09-07-2006 at 02:44 AM. Reason: Automerged Doublepost
#33
Rep Power: 0 honestly, I'd get a second job and save up for a K20 w/ 6-speed manual tranny. oh, and hawaii's got the hottest chicks. I'll trade you my manual tranny for something deluctable outta Waikiki (hope I spelled that right).
#34
...JeRsEy sTyLe...
Rep Power: 258 you need manual engine mounts.
the holes are already there so you just bolt the pedal assembly in place.
you dont need a ecu you can use the auto one.
you dont need a dash harness unless you want the sensors on the clutch to work which is no big deal to me so im not using them.
you dont need engine harness unless you want the backup lights to work, or you can wire the lights up to the reverse light sensor on the tranny
#35
do what you want
I know people that have done it and have them done for three years and they have had no problem. If u can prove you will have problems then show us
if 3 years is good for you, then go ahead~ Let us know what happens later.
#38
...JeRsEy sTyLe...
Rep Power: 258 just do the d17 and get it over with its a cheap swap and youll stil be stick while saving for the k20 which makes swapping the k20 over alot easier since all the other junk was taking care of
#39
...JeRsEy sTyLe...
Rep Power: 258 the sensor on the clutch keeps the car from starting if its not pressed in.. so if you dont hook them up you can start the car with out pressing the clutch in..
idk about the mounts i bought all the mounts just incase with ESMM
#42
...JeRsEy sTyLe...
Rep Power: 258 yea rsx pedals will work..
dont even bother stickying it because im gonna post up a complete parts list once my swap is done i got a lil held up being my car was hit an its in the body shop now and my back is killing me lol. but after that it will be done and ill post up ways how to get around not buying some parts or if you want them ill post that too
#43
Super Member
#44
Super Member
Rep Power: 0 im sure varner has the answer on what wires to bypass/tap/join together to make that work
varner what did u do so ur key wouldnt get stuck in the ignition because maybe the car thinks its still in drive
#45
...JeRsEy sTyLe...
Rep Power: 258 ill let you know when i get to that part my project got put on hold when i got in a accident in my car lol..
but i was talking to the guy i got my parts from he said he grounded out sum wires and it worked.
as for P R D its a 5 spd tranny your tellin it when to go when to shift not the ecu
#49
...JeRsEy sTyLe...
Rep Power: 258 lol u think ur excited i have all the parts sitting in my garage along with a vtec head and vafcII and no car to work on.. lol i prob wont be doing mine for atleast 2-3 weeks until my car is out of the bodyshop
#51
Super Member
#56
...JeRsEy sTyLe...
Rep Power: 258 the manual trans is same from like d16 motor and d17's just linkage isnt the same..like 96-05
but 01-05 is the same 01's had sum problems so try to get 04+ i have a 02 so w.e lol
#58
Super Member
Rep Power: 0 varner get the pics up asap man lol
so ur saying get any tranny 02+ and youll be fine? 04-05 and your golden?
i might get the axles assembly from the link Sujak posted up... no need deal with used ****
#59
...JeRsEy sTyLe...
Rep Power: 258 lol if you can get a d16 trans there built alot better then the d17 only thing is you have to rig linkage and shifter up for it to work
#60
whats the link for the stuff?
