help installing fog light
Old Mar 26, 2005
es2k2's Avatar
Proud to be a civic owner
I bought the oem replica kit from ebay and looking for people in chicago area to help me install it if you can...
i went to some auto shops today, either they are too expensive (close to 100) or they don't it at all...
maybe someone know a good place to install it? or somebody install it for me at their place... i'm willing to drive to your place in Chicago vicnity...
thanks
Old Mar 26, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Its realy a piece of cake to install. At least it was on mine.
Did yours come with instructions?
Old Mar 26, 2005
Da1lyDr1ver's Avatar
i installed the replicas before and the directions arent all that great. plus, mine didnt come with the cut-out for the bumper where you're supposed to cut a hole to fit the fogs in. its not all that bad, just takes time...
Old Mar 26, 2005
es2k2's Avatar
i got the instruction for the real oem one, but no template and i don't have any tools to cut out the bumper...
Old Mar 26, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
dremel w/ cutting disc is your friend
Old Mar 26, 2005
tbaleno's Avatar
I would suggest running the wiring harnesses first to get them out of the way. Then you can focus on mounting the lights.
Old Mar 28, 2005
es2k2's Avatar
so no one is willing to help me install it? i will take it to a shop then
Old Mar 28, 2005
civicvtec1ps's Avatar
Search and Learn
Just do it youself, it's easy.
Just take off front bumper.
Make precut for fog light outlet, run the wireharness through firewall.
Connect the wireharness plug.
Bam, you are done.
For cutting outlet for foglight, just use dremel tool.
Old Mar 28, 2005
tbaleno's Avatar
Is it realy required to take off the front bumper? I didn't have to with mine but my fender is slightly different.
Old Mar 29, 2005
no but itd prob be easier to do having it face up to you instead of working on your side
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
