CROWER STAGE 2 CAM installed...
i put the stage 2 cam in with the springs and retainers on top of the type-s injectors starts right up perfect idle at 725 i have the vtec controller but i didnt have to touch it i let the pcm reprogram and everything is mint
i havnt beat on it yet but it feels good im going to give it a little time to break in and move some of the lube i have my 75 shot on the way ill have it in by saturday so we will see how everything goes
Good luck with it. Sounds awesome already, though.
Also can you get an clip of the engine running, revving, and same at the exhaust. always wanted to hear these things, but never have yet. If not don't bother, but thanks.
I wonder what kind of AF ratio you are getting with the injectors. try letting it idle for a while then pull a spark plug and check it out.
no idle problems at all the car was running to rich with stock "vtec" engagement so i set it at 3900 with 80% throttle and that smoothed things out i have the type s injectors in right now i might change back to stock... the only reason i am keeping them in is for the spray... i want to dyno the car so i will probably get tuned while i am there but im not going to bother with the vtec controller i will most likely get the emanage first i want to be able to do some timing adjustments not only for the cam but also for the spray
if you are expecting to just put the cam in and have it be insane thats not going to happen i haven't felt the full experience yet because the assembly lube is probably slowing things down a bit ill see what i can do for a clip tonight at the races ill keep posted
mota you honed your throttle body yourself? or did you buy it
Last edited by str8street247; Jun 1, 2006 at 04:32 PM. Reason: Automerged Doublepost
Originally Posted by familycar
true you cant take fuel out with the vafc2 only add. so i would also assume that he is running pig rich.
Originally Posted by djmota
You can take fuel out with vafc2. you can also add. these adjustments can only be done a wot (or close to wot) IMO i don't think the vafc2 can adjsut enough to compensate for rsx s injectors.
ricer_em2
May 11, 2016 08:09 PM
beanhead
Sep 24, 2015 12:04 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
