Huge wings on FWD
Old Aug 9, 2004
nindoo's Avatar
Why is my vagina bleeding?
Huge wings on FWD
Lets say a civic was tuned and was capable of speeds excess of 150mph,
Would a large rear wing help to keep it more stable? Would you want more down force in the back like that on a front wheel drive car?
Old Aug 9, 2004
Master's Avatar
Banned by Admin
still wouldn't help. And you would have plenty of down force in the front considering the engine and the tranny are weighing it down.
Old Aug 9, 2004
JamesL's Avatar
JamesL is an unknown quantity at this point
i suppose it depends on different factors, but in general, if a civic was capable of speeds in excess of 150mph, then the downforce provided by the stock body (wingless/air dam less) would probably be lacking.
im not sure where you are making that up from... why do you think race cars have front air dams and/or rear wings? downforce has nothing to do with the engine and the tranny... that is simply weight weighing down the car. downforce is, hence the name, a force created by airflow over and around an object. air dams and spoilers/wings create downforce, not heavy engines.
the air flowing underneath a moving vehicle creates lift, this happens at any speed, although it is exagerated as the speed increases. aerodynamic bits and pieces are used to create negative lift, or downforce, to provide more traction as speed increases as opposed to less.
Old Aug 9, 2004
nindoo's Avatar
At normal high speeds would a front air dam and skirt make a diff on traction, lets say speeds between 100-125mph?
Old Aug 9, 2004
Master's Avatar
Banned by Admin
^^^yes but not enough to really worry about it.
Old Aug 9, 2004
JamesL's Avatar
it depends. are you driving your civic on a race track? are you coming off the straight going into a turn at 100-125mph? if so, then absolutely.
if you are driving 100-125mph on the highway in a straight line (which is btw) then the difference wont be as apparent.
maybe you could clarify what type of driving you intend on doing... and then i could help you more. aerodynamics are infinitely more important on race cars than they ever will be on street cars "driven fast on the street".
Old Aug 9, 2004
Master's Avatar
Banned by Admin
With only going 150 mph it would still not be needed. Just lowering the car can help with the down force. As in making less space for air to go under the car to cause lift. You wouldn't need a front air damn. Shoot look at all those muscle cars they don't have air dams or wings at that matter. Sure they are rear wheel drive but they give the speeds that we are talking about and they don't need anything.
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
People seem to forget... as speeds increas, so does a cars tendency to oversteer.... SO... as JamesL said, if you are on a race track then Yes a wing of some sort may be of use. (down force is free traction afterall).
The big thing I see though is that people seem to think that the Dinky little wings they put on their cars will help..... when 1. its too small to make a noticeable difference (Except by adding more drag) and 2. its attached to the weakest piece of sheetmetal on the car(the deck lid).....
If you want to learn more about aerodynamics in regards to Racing cars...
Book
http://www.amazon.com/exec/obidos/tg...16617?v=glance
websites
http://www.belmont.k12.ca.us/ralston...ar_Racing.html
http://www.gmecca.com/byorc/dtipsaerodynamics.html
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
Master, think of this.... in an F1 car they have both a front and rear wing.... those wings are used to create extra traction for the corners.. on average the speeds in which an F1 car takes a corner is between 60 and 90 MPH.... so your 150+mph thing is bubkiss.
Downforce is FREE traction for the corners If you understood how tires make traciton you would understand this... You are increasing the load on the tires with out increasing the weight of the car!
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
Also, Look at Improved touring cars....
Such as this ITB BMW 2002
notice the big air dam in the front? that really helps these cars, but guess what?? on a race track an ITB car woll only see max speeds of around 110-120 MPH...... and thats at the end of a straight a way... Cornering speeds (where the down force from the air dam is actually usefull) is aroudn 30-60 depending on the sharpness of the corner.
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
Heres an ITC car, wich is an even slower class of car then ITB...and it still has an air dam!
Old Aug 9, 2004
JamesL's Avatar
i guess it took you a while to think of a comeback huh?
i assume "master" doesnt stand for the degree you have in physics either?
Old Aug 9, 2004
JamesL's Avatar
and Zzyzx... you are one of the few people's opinions i respect on this forum.
i left in the first place because of the never-ending onslaught of ignorance.
but, its always good to hear from you.
Old Aug 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I am ignorant
free traction owns
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
The problem with the imports sporting the Tuner wings....
1. most are too small to make any signifigant down force.
2. most are not placed in areas of clean air flow.... (thats the reason why these porsche wings, though Ricelooking, are mounted where they are..)
3. They are attaced to one of the weakest part of the car... the center of the trunk.
4. even if the wing is in "clean air" the wing its self is not tuned correctly, causeing more drag then downforce making it worthless.
5. the people sporting these whings never do the type of driving where it may be usefull (Dragrace Vs Road course).
Old Aug 9, 2004
TurboDieselDrew's Avatar
TurboDieselDrew is an unknown quantity at this point
Agreed.
Old Aug 9, 2004
nindoo's Avatar
What is the purpose of roof scoops? Do they have anything to do with down force?
I've learned a lot at this forum, very competent people here.
Old Aug 9, 2004
Zzyzx's Avatar
Autocross Junky
Typically on a race car (Or rally car) they are used to get fresh air to the driver/co-driver of the car.. on some Mid and rear engine cars, they are used to get fresh air to the engine.
as far as scoops and downforce.... well they make drag thats about it.
Old Aug 10, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
looks like zzyzx has this thread covered haha
Old Aug 10, 2004
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
yeah thanks zzyzx for your knowledge on this topic i have learned a lot from your posts thanks
Old Aug 10, 2004
nindoo's Avatar
I have the stock spoiler on my car, I got it strictly for performance.
lol
Old Aug 10, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ oem spoilers are always awesome looking
Old Aug 10, 2004
Dragoneye's Avatar
Dragoneye is an unknown quantity at this point
Most of the WRC cars have roof scoops..
I would think they would do SOMETHING. maybe since most roof scoops you see now don't have an opening, that's just drag.
I don't like spoilers, generally, but I do like roof scoops.
Old Aug 10, 2004
WhiteCastle's Avatar
roof scoops such on the mclaren f1 act as a ram air system. The ones on WRC cars act by providing fresh air to the drivers.
Old Aug 11, 2004
Dragoneye's Avatar
ahhh, that makes sense, with all that exhaust and dust and shiet flying around.. prob get fairly hot in those cars
GolNat
Nov 27, 2018 03:32 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
tropicola
Sep 25, 2015 07:02 PM
curaze
Sep 22, 2015 08:27 AM
