Type-R Help!!! I am civic ignorant
Leatherman
Rep Power: 0 Re: Type-R Help!!! I am civic ignorant
LOL!!!!!
I am ignorant about Honda everything.
My other vehicle is a fully deleted, chipped and built 2010 Ram 3500 Cummins 4x4
I need to learn about the doo’S and dont’s about honda’s
Received 1,146 Likes
Rep Power: 485 Re: Type-R Help!!! I am civic ignorant
Drive it first. Maintain it well. Mod where you see fit if need be. If you decide to mod, do lots of research first.
Leatherman
Thank you.
I am driving it full time. Winter tires are horrifyingly expensive, but it drives awesome. TONNS OF POWER!!!!
are there any groups or shops in Saskatchewan???
i am in the yorkton area
Buy a set of 16'' steelies. Premium tires (Nokian, for instance) won't run you for more than 200$ each.
16" rims are too small for the FK8. 18's at a minimum to clear the brakes. I don't feel like searching too hard, but my quick google search didn't yield very much in the way of 18" steelies with a 5x120 bolt pattern
"Honda - tried, true & tested...!"
Congrats.! Leatherman on Your New Civic Type R red is one of my Fav"s
Only future mods for extra power i would sereously consider doing for a little more added power is getting a ECM re-flash using Only HondaData"s re-flash. it will allow you to turn up the Factory tuned settings that are currently tuned for fuel effiecency and
emmisions to where You can safely turn them up from stock. to things like stock 3psi of turbo boost to 6 psi turbo boost and many other parameteres of moding & adjustments can be safely done & found . looks great.!
