rear swap done
my civic gets me pu**y.does yours???
Rep Power: 0 rear swap done
well i picked up the rear setup for 250. heres the pics. i know my car is shitti right now. but i have rear disc brakes oh i also painted them black.
Shot with HP PhotoSmart C945 (V01.68) at 2007-07-14
I wil fix vBPlaza today
1 Post
Rep Power: 280 Re: rear swap done
nice man!! i'm looking around for the SI's rear brakes as well! ive been asking around on ephatch.com
just before anyone else asks, what all exactly did u need? like the full list.. yea i know it can be found searching, but people will still ask i bet you
This is Myspace
1 Post
Rep Power: 235 Re: rear swap done
man those look good. what are u dropped on..if u are at all. ur front looks kidna low but the rear looks kinda stock... and what size are ur wheels.?
Rep Power: 0 Re: rear swap done
i needed the rear spindels,hubs,rotors and calipers.also the rsx ebrake cable.im dropped on tein springs and sitting on 215/35 r18.the back has one jack under it still but for some reason the rear on mine always looks higher.anyone know why?can you put the shock in the back backwards?a shop did mine but they say its good.any help?
did you honestly feel a difference in braking? i know there has been some debate about changing the master cylinder to that of an RSX or Civic SI. i'm assuming you didnt do this? so how about your input?
Received 1,144 Likes
Rep Power: 485 Re: rear swap done
nice.. i paid 500 for mine so now i feel kinda gipped.. lol.. oh well.. looks good
both eps and and rsx will fit.no i didnt do the master swap but once i can get on i will.braking does feel different.and my ebrake is strronger it seems.try ephatch to get them.i got mine from a member here.had to drive 3 hours to get them but i wanted them.
^^^ so you would say that braking now with the rear disc set up is better now, than when you had the drums?
i'm only asking this because i have the rear disc swap sitting in my garage, and i'm debating whether i should even put them on or not.
yeah i dont have to mash the brakes to stop.its a slight difference.plus i like the way a rotor and caliper look behind my rear wheel.its better than that ugly drum.
1 Post
Also you all i have put up a want ad on ep3hatch.com and its been a week without a reply :/
Rep Power: 450 Re: rear swap done
i signed up on ephatch like a month ago and within 5 mins i had myself a set for $220 shipped
there isnt a real difference in braking, just looks a whole lot better
i found a set on clubrsx. but you will have to get si hubs and rotors.the guy told me 300 shipped for them.that was two days ago ill try to get him again.
i found a whole swap including the front and rear disc swap for 500 obo.not bad.i saw on here that you can get 5 lug swap with oem axels so you might wanna look that up.
A long winded 7th genr
Rep Power: 263 Re: rear swap done
We've debated the performance gains when swapping to a rear disc brake in another thread a while back, and the consensus seems to be that the brake performance is in fact increased still utilizing the master cylinder. I discovered a while back from a guy at my shop saying that disc brakes use less brake fluid pressure then drums. I'm sure that if you were to upgrade to disc, and then upgrade to big brakes then it'll be even more of an increase, but just stock discs is without a doubt better then drums.
1 Post
See i like my rims that i have right now, so no 5 lug for me
1 Post
sorry to ask again, but just to make sure i told this guy everything i need, tis the rear spindles(knuckles),hubs,rotors and calipers, then the e-brake cable. right?
spindles/ knuckles, si hubs to stay 4 lug,rotors, calipers, brake lines from the calipers to the body, calipers should come with this if you get from the junkyard, and rsx ebrake cables.btw i have some extra rsx cables for sale.
Rep Power: 226 Re: rear swap done
FYI. Going from stock brake ( fronts) to AEM BBK, you would actually gain distance brake (or whatever you call it) which is a no good. but still it looks cool!
1 Post
like with me all i did was replace my fronts with brembo blanks and used some hawk pads, and my braking distance has decreased.
yep, the Big brake rotors not the ones that's the same size on our stock. (if same size then yes, it will help) Totally forgot the explanation but it has something to do with the size and all. this was covered plenty of times here. I am pretty sure someone can explain it like boilermaker or gearbox even.
