My Parking light REAR light wont Turn on!! HELLP 7thgners!!
Rep Power: 226 My Parking light REAR light wont Turn on!! HELLP 7thgners!!
ok, well i was testing something in the rear parking lights wiring (and tried to be a know how guy)and then next thing i know.. POFFF the rear talights parking light wont come on anymore, i mean the brake light works but when i turn my parking light, just the front (and sidemarkers since i have them) turns on except my taillight lights!!!
do you guys think its the fuse? if so, can someone please help me out which one i should change?
thanks!
J
thanks!
J
Rep Power: 0 it should be fuse below ur steering wheel. and if u don't have spare, just go to Autozone to get some with the right amperage. and btw, if u duno which one is the fuse, just check the piece of sticker on the bottom steering cover. its at the back, bro.
1 Post
Rep Power: 364 Did you happent to check the bulbs?
Oh.. and sadly I have the same problem.. except someone hit my car when it was parked outside my house tonight.. anyways.. when the trunk crumpled, the wires that run across the rear (above the jack) were severed by the sharp metal as it crumpled and yeah, my rear lights dont work any more either. Check it out.
IMO an open fuse would make all of the parking lamps inoperative.
If you have a meter the RED/YELLOW wires are what you would be working with. Use the chassis as the meters ground start at the parking lamp sockets and work backwards. ( You could also use a test lamp on this circuit as well )
Rep Power: 228 It's Probably a the Fuse call "Small Lights" its located under your hood its a 15A Fuse.... If im not mistaking your interior Dash and Illumination isn't lighting up either. Check the 15A Fuse called "Small Lights" and see if that is blown. And then after you fix dont **** with the wires.
Rep Power: 244 And to help, there is a fuse puller and extra fuses in the fuse box under the hood. Just pull the fuse and look to see if the metal piece inside is broken. If it is replace it, if not it is okay.
Rep Power: 226 It's Probably a the Fuse call "Small Lights" its located under your hood its a 15A Fuse.... If im not mistaking your interior Dash and Illumination isn't lighting up either. Check the 15A Fuse called "Small Lights" and see if that is blown. And then after you fix dont **** with the wires.
Dorval Andre
05-01-2015 09:37 AM
