In the middle of installing gauges confused about a few things help would be apprecia
420 Member
Rep Power: 222 In the middle of installing gauges confused about a few things help would be apprecia
First I wanted to know if all the gauges would still work if I hooked them up like this
Then I wanted to know for the power source which grey/red wire is it behind the gauge cluster there are 3...
is it the one I did it on?
2?
or 3?
in the middle of this so any help would be appreciated o and how do I ground it? do I need to get a grounder to put behind a bolt or can i just stick the wire behind a bolt and screw the bolt in? a bolt such as the grounder for the cig lighter
2?
or 3?
Rep Power: 0 if the 3 prong connectors are for the power then yes it will work. The ground behind the Cig. Lighter is perfect, but i wouldnt try just wrapping the wire and tightening the bolt down, i would use a round electrical connector and bolt it down like that, and for the power wire i cant help you there sorry
mistermenphis22
04-03-2016 08:06 AM
zaboomafoozarg
05-30-2015 09:21 AM
tylerginevan
04-27-2015 12:29 PM
twtron
04-17-2015 12:09 AM
