K20 valve cover...almost. lol
#32
Remebers the old days
1 Post
Rep Power: 273 I stripped all the wires apart and ran the ALT wire around behind the valve cover under the plastic tht holds the Trottle cables and stuff. That made it alot thinner.
#34
Rep Power: 248 there are 5 bolts on top of the valve cover un screw them.. before you do that take out everything that obstructs it.
when you tighten them make sure to only tighten then at 7lbs torque no more than that
#35
Rep Power: 0 Hey guys just a little more info. Here is some more wrinkle paint, vht paints They also sell this at my local oreilly's so its easy to get if you dont want to order. It has a heat rating of 350 degrees. Comes in Red, Gray, and Black. I wonder what the black would look like??
#36
...JeRsEy sTyLe...
Rep Power: 258 there is also so other bolts behind an around the valve cover thsat hold sum cables and wut not so make sure you get those b4 you go prying at the cover
#39
1 Post
Rep Power: 273 It is the dezod first test manifold. The one he used to start buildind all hin turbo kits. It has cracked about 5 times and I just keep welding it back until I can get a new one.
RIPSAW
08-16-2015 12:14 PM
fred57
08-01-2015 08:45 AM
Ariah J. Davis
07-20-2015 07:15 AM
