3 02 sensors!!!!!!!! - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 03-15-2006   #1
nighthawk1903's Avatar
nighthawk1903 is an unknown quantity at this point
I have a 2003 Civic HX with 3 thats right 3 02 sensors, now i put on a hp racing header an high flow cat an boom check engine light!!! now i got 1 02 senor bypass on the one after the cat(not drilled out, is this a problem) still with the check engine light on) i just installed a sencond 02 sensor bypass on the second 02 sensor, i don't have one on the first don't worry, i'm just wondering if there are any other civics out there my year or so that have had the same problems an how did you fix them. An what models have 3 02 sensors lx/dx/hx????????????? i take the ex's only have the 2????????
nighthawk1903 is offline   Reply With Quote
Old 03-15-2006   #2
let the devil out
eye_see_you's Avatar
eye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud ofeye_see_you has much to be proud of
the mechanical O2 sensor has to be drilled out on one defouler and drilled center in the second defouler now as for 3 sensors.. huh..
eye_see_you is offline   Reply With Quote
Old 03-15-2006   #3
R1Style's Avatar
Ya why do you have Three o2 sensors?! Where is each located according to your stock exhaust?
btw... try getting an o2 sim to get rid of the CEL.
R1Style is offline   Reply With Quote
Old 03-15-2006   #4
I guess pics were a must on this an both 02 sensor bypasses installed were acually predrilled.... my bad.....
BTW! Notice the cat upside down then rightside up making 2 02 sensors in the stock manifold, an then one in the rear of the cat!
ID:	65098   Click image for larger version
ID:	65099   Click image for larger version
Old 03-15-2006   #5
I need help c'mon somebody say something
Old 03-15-2006   #6
R1Style's Avatar
man... I honestly have no idea.
Someone on this board made o2 sim that taps into your ecu. Maybe look into that for getting rid of your CEL.
btw... post this in the tech forum... you might get more help
Old 03-15-2006   #7
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
?wow!?
SODJAZERO is offline   Reply With Quote
Old 03-15-2006   #8
JP375's Avatar
JP375 is an unknown quantity at this point
Civic HX? Isn't that the so called "lean burn" model only available in California? My guess is that it has 3 o2 sensors to have even more precise control over the mixture. If it is indeed the HX I am thinking of, you should probably just stay away from modding it. The ECU is programmed to run the engine for optimal fuel efficiency. (even more so than a standard civic)
JP375 is offline   Reply With Quote
Old 03-16-2006   #9
well, i live in ohio, so what the **** do i do, i have 2 02 bypasses on there an the check engine is still on, do i "A" have another problem or "B" there just not working correctly??????????????????
I think all my fun an hard work is just gonig to dissapear because of the ******* salesmen or sold me the
car, I guess i will have to be done moddding it that sucks,cuz thats the only reason i bought the car..............
Anybody else got anything??????????????
Old 03-17-2006   #10
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
I have that in my civic and it never threw a CEL
2k1civic01 is offline   Reply With Quote
Thread Thread Starter Honda Civic Forum Replies Last Post
Please Help: Need Correct O2 Sensor (quickly?) BootyDo 7th Generation Civic 8 06-21-2016 04:45 PM
02 Civic Lx stalling out after camshaft sensor replacement Drix Mechanical Problems/Vehicle Issues and Fix-it Forum 20 08-05-2015 11:48 AM
02 civic starts, then stalls... Green02civic Mechanical Problems/Vehicle Issues and Fix-it Forum 13 07-27-2015 11:48 PM
98 civic, HELP!! Dani1993 6th Generation Civic 1 07-24-2015 10:02 AM
P0171 Headache mistermenphis22 Mechanical Problems/Vehicle Issues and Fix-it Forum 13 07-13-2015 05:43 PM
Tags
02, 97, cat, check, civic, engine, flow, high, honda, hx, light, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
