lens paint or lamin-x for oem fog lights
Rep Power: 0 lens paint or lamin-x for oem fog lights
I just got in some oem fogs.. would you use the lens paint or lamin-x . I have a half a can of the spray already from a friend or should i buy the lamin-x for 15 bux, i know its better for rock chips but i heard that it burns the fog.
Rep Power: 787 if you have oem bulbs, then no it won't melt the film. mine only melted when i swapped the nokya bulbs in there. i'm back to stock and thinking of either gettin clear or yellow film.
Rep Power: 787 i have nokya 2500k H11 bulbs for $15 shipped if you want. they are very yellow. i just ordered clear laminx for my stocks.
Rep Power: 0 thanks but i actually got lucky and im picking up a new set for 12 bux from spw. why are you getting rid of the bulbs btw. The yellow looks better with the yellow cover and the yellow bulbs right?
I would go lexus oem capsule but im not willing to spend that much
Rep Power: 237 so the combination of lamin-x with nokyas melts the film? that sux. has anyone ever od'ed and tried to use nokyas with a sprayed and lamin-xed lens?
Originally Posted by bhoy
i bought a bulb cost me 30 bucks in the dellership its ultra yellow
Rep Power: 282 yea, as gearbox said, the film is likely to burn if u use the diff bulbs, i have yellow lamin-x and noyka arctic yellow bulbs, as long ias u dont leave the car siting there for a while with the fogs on, then ur fine, its when the car remains in one spot for an extended amount of time with the fogs on, thats when the burning occurs, its happened to me on both lights and i just replace the film, its easy as hell to do, and i always keep a sheet extra just in case, but to me, the film looks a lot better then the paint, but either way its up to u, all depends on what u want.
Originally Posted by 05_ CivicJDM
Did you get the fogs from ebay? Post pics when you have it all set up...
DU MA Con Cac
Originally Posted by 2k1civic01
where the hell do you buy lamin-x from?...lol pep boys or something...
Superior Evolutionary Element Destined-factor
^^ thats why u need nokya arctic yellow bubls like mine :-D soooo hotness
Rep Power: 282 yea ive had to replace it once, but that was my fault for leaving my fogz on for 20 min with out the car moving, other than that, nah no prob, its easy to replace, just takes some elbow grease.
yellow bulb
Hi,
All yellow bulb I have seen are 100W, the factory recommanded 55W. Would 100W overcurrent and kill the harness?
thanks
hi
yea very possible, the ones i have are actually 80w.
hi,
So you have not burn anything?
Can the 80W bulb survive long (2-3 years), being the wrong wattage?
thanks
Rep Power: 372 Don't worry about how long they will last, they are only about 20 bucks
