Problem with magnaflow exhaust
One Slow Civic.... But I can take turns pretty well :-)
Rep Power: 0 Problem with magnaflow exhaust
Anyone with a magnaflow exhaust ever have any problems with banging against the underbody? Or the bumper? Recently... my exhaust was banging off the underbody right about the axle. So I turned the midsection hanger around... and it stoped... Until I bottomed out really nicly... Now its making a clanging sound... Its hitting the body again... I only tried to adjust it cause it was hitting the bumper and also hitting the underbody...
If anyone has experienced this, can you tell me how you fixed it? Or maybe if you think you know how to fix it... Please help me.
Rep Power: 0 ok, mine does it really bad after i bottom out a few times. I have a full cat-back system as do you I think, and it bangs on the whole entire underbody of the car. For me it was the mid section that was banging around. I took it to my exhaust shop and heated up the rear and just pulled down. Take it to a place or do it yourself.
Rep Power: 0 Hmm.. You know of any of the major chains that do work like that to exhausts? And yes, its a cat-back.
Life Begins > 6800rpms
Rep Power: 350 i welded my connections and removed all the u clamps. now my midpipe heat shield rattles and that has to be fixed. i need to raise the car back up so the midpipe doesn't lay on the ground.
Rep Power: 0 Think my best bet would be to take it to a muffler shop and tell them to go nuts and do all they can to fix it?
Rep Power: 0 Intresting... It doesn't make the sound today... WTF! It seems to only do it at night... I'm confused...
juror
05-26-2015 06:35 PM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
