View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#662
Received 1,146 Likes
Rep Power: 485 Re: K24 vs. K20?
Yeah. I had that backwards
Measurements were good. Mixed up respective blocks and heads
#664
Received 1,440 Likes
Rep Power: 338 Re: K24 vs. K20?
why would that cause reliability concerns?
#667
?!? Why would upgrading the cams would reduce reliability?!?
#669
Re: Are polyurethane bushings worth it?
my answer is , what you intend to use it for?
for a race car gaining stability os engine not moving and getting extra vibratiomaybe.. on top race team.... for everyday runner, unless u build a monster why do it?
what u going to gain besides vibrtion and stiffness a touch...
money spent elsewhere can get u more performance...
for me is always benefit vs $$$ , and what am trying to do..
#670
Which sway bar bushings should I buy?
I bought a 21MM rear sway bar from a 2006 RSX-S, which obviously won't work with my 12MM bushings. My question is who makes good polyurethane rear sway bar bushings for an RSX-S? I searched for about 30 minutes, but I can't find any. I can only find 19MM bushings, but I need 21MM. Thanks!
#671
Rep Power: 338 Re: Which sway bar bushings should I buy?
Did not know they were so difficult to have poly bushings..
try searching on RSX forums, maybe they have an answer.
https://honda-tech.com/forums/acura-...-civic-ep3-32/
http://forums.clubrsx.com/
#673
Search this Holmes: http://www.moog-suspension-parts.com...r-bushings.asp
#674
#675
Rep Power: 485 Re: Which sway bar bushings should I buy?
general consensus is you need to get the universal 21mm ones, but there have been issues with them fitting in the OEM bracket. Most people have resorted to saying screw it and going with OEM rubber bushings
#676
#678
OEM rubber bushings do their job well. If you're that gung-ho about going poly, make sure you stock up on some silicone grease
#679
I prefer poly because I never have to think about them again. They won't crack, sag, dry out or turn to mush if oil leaks onto them. Rubber bushings also flex, limiting the performance of the sway bar that I just spent $77 on. I have heard people complain about squeaking, but I have always used Energy Suspension bushings and lubed them up good with the included grease, and I never heard a single squeak. Even if they did squeak, I much prefer squeaks to decreased handling performance. Just a personal preference.
#680
Prelude Owner
Those amazon ones or these should work
http://www.energysuspensionparts.com/9.5125
I doubt you would notice the difference between rubber and poly for a sway bar. Other bushings yes. Those other reasons are great for going the poly route though
#682
I doubt you would notice the difference between rubber and poly for a sway bar. Other bushings yes. Those other reasons are great for going the poly route though l:yup:
#683
I had ES poly bushings on my 2002's front LCAs. Even greased up, those things squeaked like a **** after some time. Luckily I installed zerk fittings to lube them up, but silicone grease was thicker than ****. Sticky AF, too
#684
Did you use the black or red ones? I have the black ones. I believe that the black ones have graphite in them and the red ones don't, so maybe that's why mine don't squeak. Anyways, if mine squeak, I'll just install grease fittings too. That's a great idea, thanks. Also, did you notice any improvement in handling with the poly bushings? I noticed that the steering felt more precise and responsive than with the rubber bushings, and the ride quality didn't suffer. However, the rubber ones that the poly bushings replaced were cracked and worn out, so who knows if the improvement was from having poly bushings or new bushings.
#685
Black. I replaced bushings that were gone (bolt hole bit fell right out). I chalked the steering response improvement to having actual bushings instead of broke as hell ones
#686
Help! Strut bolt broke off!
I had a difficult time replacing my back struts and installing lowering springs this weekend. The first one, the bolt was seized to the metal sleeve inside the lower bushing, and it broke when I tried to break it loose. I took off the whole rear trailing arm and cut the bolt, and unscrewed it with vise grips. It only took me the whole day, but I got it done. However, the second strut didn’t go as well as the first one. The lower mounting bolt was so rusted to the lower trailing arm that the head broke off when I barely turned it. FML. So now the strut isn’t held in very well and it makes clunking noises when I hit bumps. So how do I get the bolt out now? I am thinking I will have to take the lower trailing arm to a machine shop, but any ideas would be appreciated. Thanks!
#687
Received 1,126 Likes
Rep Power: 190 Re: Help! Strut bolt broke off!
Penetrating fluid and heat are your friends when working on Hondas.
You can try welding a nut to the broken bit. Apply lots of penetrating fluid and let it soak in. The heat from the welding may be enough, but you can apply some heat to where to bolt threads in, just don't heat up the strut body or it might explode or melt seals.
Could grab a used trailing arm from a junkyard. Call the machine shops and try and get a price first, machining cost may be more than another trailing arm.
#688
#689
