Tein Springs? SKA22 AUB00 TEIN s Tech
Old 06-02-2013
Besimple1's Avatar
Besimple1 is an unknown quantity at this point
I am getting some conflicting specs from different sites about these springs. Some say the only work on 01-05 coupes and others say they will work for all models. Has anyone used these on a 4dr? I have an 03 civic hybrid. It has the same struts as an 02 coupe. Any info would be helpful. Thanks
Old 06-03-2013
sl33pyriceboi's Avatar
Re: Tein Springs? SKA22 AUB00 TEIN s Tech
as far as suspension spring fitment, they are all the same for 01-05.
however, the better companies will make different sets for the coupe and sedan. the difference is mostly found in the rear spring in order to compensate for the extra rear weight of the sedan.
Old 06-03-2013
Prelude Owner
GolNat's Avatar
Yea, I have read that if you have coupe springs in a sedan then the back will sag and if you have sedan springs in a coupe then the back will be higher.
My Eibach's made my sedan sit lower in the back, I'm thinking that's why.
GolNat
11-27-2018 03:32 PM
skeener51
10-01-2015 05:56 PM
2002ExCivic
22
09-28-2015 08:29 AM
TheRiddicles
09-21-2015 03:43 PM
TheRiddicles
09-21-2015 01:28 AM
Quick Reply: Tein Springs? SKA22 AUB00 TEIN s Tech
